turbo squell ?
Old Aug 22, 2006 | 08:35 AM
Clint Knotts's Avatar
Clint Knotts
turbo squell ?
I get a squell sound from my 6637 intake when the boost and rpm is up
and change gears.[automatic]The boost drops off and rebuilds as the rpms build.The sound is not a whoosh,[like air going back though the intake]it is a squell.Maybe it is some kind of intake leak but I dont think so.the path of least resistance would be the filter.The truck only has 55,000 on it.Maybe I will hook the waistgate line back up and see if that makes a differance.Any other Ideals
Old Aug 22, 2006 | 08:48 AM
bloomy63's Avatar
bloomy63
you ought to check the end play in your turbo, the compressor wheel may be rubbing against the housing. this is very bad.
Old Aug 22, 2006 | 09:15 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
bloomy, dont scare him like that.
Clint you must have an open exhaust. i just rebuilt my turbo about 2-3K miles ago. i have a completely open exhaust, with a 1.15 turbine and no EBPV in the way. i love to build boost right at the end of the gear so i can let off and let the turbo squeal. i think it is pretty awesome. nothing to be scared about. it is defanitely the turbine whistle, not a compressor noise. you can hear it out of the exhaust, not the intake.
Old Aug 22, 2006 | 09:22 AM
Clint Knotts
OK I just checked the end play and there is none,However I did find the hose clamp at the turbo loose.I also ran a bead of silicone around the tube that gose into the filter and hooked the red line back to the waistgate.I'll see if that helps.On a long hard pull at WOT it was building 20 and 21 lbs boost,empty it will only build 15lbs boost.The egt would not go over 1000 deg.[stock PCM] This seems about right to me.Also I dont notice the squell noise when empty,but again it is not building that much boost.
Old Aug 22, 2006 | 09:38 AM
Clint Knotts
It sure dosent sound like it is coming from the exhaust,it is coming from under the hood.The kind of noise like letting air out of a baloon real slow or a bad bearing in a blower motor.just a short burst and gose away.The bearings in the turbo are good and tight so I dont think that is the problem.It may have been the loose clamp I found but I wont know for sure until I get hooked to the 5th wheel again in a couple of weeks.I do have a 4'' exhaust,boost reg,sonnax kitt,and gauges.DP-tuner is on order.
Old Aug 22, 2006 | 10:29 AM
cangim's Avatar
cangim
Mine will do the same thing, more of a bearing squeal, may be the same thing you are referring to. I rebuilt the turbo, replaced the journal bearing, made sure everything was tight no leaks and such. Guess what, it will still do it when pulling heavy load. I guess I will wait for something to break as I have no idea what is causing the noise. Maybe it is all air and sounds different, but mine definately is coming from under the hood driver side. But is sure make one nervous not knowing what is actually is.
Old Aug 22, 2006 | 10:39 AM
Batgeek's Avatar
Batgeek
I get that same sound from mine, but it comes from the fan clutch and not the turbo.
Old Aug 22, 2006 | 10:42 AM
cangim's Avatar
cangim
Now that you mention it, I have heard that as well, I replaced the belt on mine. Still made no difference, probably the actual fan clutch failing. I am thinking of going electric once it really needs to be replaced.
Old Aug 22, 2006 | 10:56 AM
BuickTurbo's Avatar
BuickTurbo
It's the same thing as the whoosh, just at higher pressure it sounds like a squeel or bark.
Old Aug 22, 2006 | 02:12 PM
PowerstrokeJunkie
now that i think about it, BuickTurbo has it right. i get a woosh below 10 psi and the squeal above 10psi. dont know what it was in me that made me think that the turbine was making that.
hopefully my ATS will amplify this sound, because i LOVE it.
Old Aug 24, 2006 | 09:41 PM
forddork's Avatar
forddork
i i cant find the tsb but my 02 have similar problems and it ended up being the belt tensioner pully.
tkupiec
Aug 22, 2010 02:44 PM
wheelie31
Jun 20, 2010 10:36 PM
droppedf100
Feb 22, 2010 06:48 PM
swaybar
Jul 12, 2008 06:11 AM
yomow
1978 - 1996 Big Bronco
Jan 9, 2005 03:03 PM
