Budget 390
Old Aug 21, 2006 | 08:09 PM
jseim44's Avatar
jseim44
Budget 390
Hey guys, I'm looking to build a strong 390 for my old 69 F-250. Right now it is bone stock (2bbl, logs, etc). I'd like to put a 4bbl on it, headers, a cam similar to the 941, and some head work. I'd like to keep this as cheap as possible, but I also want to put the hurt on alot the Chevy and ricer boys in my town.
Now, one quick question since I'm browsing around.
Right now I'm looking at engine kits on Northern's website and the 390 car and truck kits both have "recessed head pistons" (dished?), and the 360 kit has flattops and better cam choices (Comp instead of Federal Mogul). I guess I'm wondering if I could get the 360 kit since it has flattops, or if that will put my compression too high for pump gas. The 360 kit is also the cheapest. I don't see any pistion specs on their site, but maybe someone will have them and could help me out.
TIA,
Jake
Old Aug 21, 2006 | 08:58 PM
Barry_R's Avatar
Barry_R
PM me - - the only way to get good compression on a budget 390 is with forged pistons. I think I can help...
Old Aug 21, 2006 | 09:51 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
There is a way, using 360 pistons too...
I believe someone has already done this. Anyone want to chime in?
Old Aug 21, 2006 | 09:56 PM
jseim44's Avatar
jseim44
I guess I should add that I'm not planning on any happy juice or anything like that, so stock parts would work. Could a person just use 390 crank and rods with 360 pistons and still have like suitable compression for pump gas?
Barry, you have a PM.
Jake
Old Aug 21, 2006 | 10:27 PM
FalconStng's Avatar
FalconStng
I used the 360 pistons in my build. A stock 360 flattop piston will usually put you in the 9.5 - 10 to 1 range, depending on head cc's, head gasket used, block decking, etc. My build put the pistons about .012 below the deck. I used the Mr. Gasket steel shim head gaskets and D2 heads. I think that's about the cheapest way to get a decent compression ratio on a truck 390. Don't kid yourself though...there is no cheap build 390. It's addictive...first you get the flatop pistons....then you want to port and polish the heads....you go big enough on the cam that you've got to at least change valve springs....then it's an adjustable rocker assembly....and it never ends....LOL.
Good Luck!
Tracy
Old Aug 22, 2006 | 09:49 AM
krewat's Avatar
krewat
Tracy, thanks for the input! 9.5-10 is pretty middle-of-the-road.
I used the forged TRW L2291 flat-tops. I topped out at around 11:1 according to my machinist.
After taking it apart, while scrapping the highboy, I found that when I had a massive intake leak, all that oil caked up on the pistons. No wonder I had a heck of a time with pinging. I don't think there was any "deck" left after all the crud built up on the pistons
Old Aug 22, 2006 | 04:28 PM
73F100*8Mile's Avatar
73F100*8Mile
ya i rebuilt my 360, wasn't happy with no power so i put a 390 crank and rods in with the 360 pistons which were silvolite 1130's with a crane 941...what a wakeup!
Old Aug 22, 2006 | 05:10 PM
baddad457's Avatar
baddad457
Silvolite also offers cast flat tops for the 390. $84 a set thru Summit Racing. They also see Crane's 272 degree Energizer cam that works well with those pistons and C8/D2 heads. The cam and lifters sell for $125. But after all that, I still wouldn't bet on an F-250 in a race with a lighter vehicle. That huge Dana 70 rear and beefed up suspension adds a lot of weight you don't need for drag racing.
Old Aug 22, 2006 | 09:17 PM
jseim44's Avatar
jseim44
It actually just has a Dana 60, but it is still heavier than a half ton.
Yea, I know it's addictive. I was planning on porting the heads alittle already. I completely forgot about stiffer valve springs. I'd kind of like to get a rough price estimate put together first to see where I'm at, and then go from there. If someone could help me get a build put together and get prices on it all, that would be awesome.
Thanks guys,
Jake
Oh yea.......it's either this or a 350 ***** and find something to drop it in.......and I'm tired of the way every 350 ever built sounds!!!!!!
Old Aug 22, 2006 | 10:12 PM
mswift's Avatar
mswift
You ment to put a 1 instead of the zero, RIGHT? I'd rather see a cleveland or windsr, rather than that "other" motor. Hell, even a 400 is better...
Old Aug 22, 2006 | 10:22 PM
jseim44's Avatar
jseim44
Now, if I could find a decent Ford Motor Co. product in my price range, then I'd rebuild it with whatever I see fit (302, 351, 460 - you get it). However, I'm not having much luck. Bottom line is - I have to have something since this is for a class at school. I'm also a senior in high school, so I'm supposed to be saving for college. Don't get me wrong, I'm keeping the 69 forever, and someday it will be restored, but I just don't have the $$$ right now.
Old Aug 22, 2006 | 11:40 PM
mswift's Avatar
mswift
Heck, get yer hands on an old flathead. Your teacher will give you an A just for nostalgia.
Old Aug 23, 2006 | 05:15 AM
baddad457's Avatar
baddad457
Why do we have to price everything? Your fingers broke? Like I posted earlier, pistons, $84, cam $125 add to that a Performer RPM intake (what? $300? ) Headers,carb, rings, bearings, gaskets. Do the math. You're in school, you ought to be able to figure that part out. Just don't bet on the F250 in a race. It ain't a race vehicle, but more like a race car hauler.
Old Aug 23, 2006 | 06:03 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
LOL Baddad, I guess it all depends on what you build for an F250!!!
Russ
Old Aug 23, 2006 | 10:17 AM
jseim44's Avatar
jseim44
If my fingers were broken how could I be typing? With my nose? I don't think so. Haven't you ever heard of helping some people out when they have questions? Obviously some other people here have, and I thank them for that. I've never built a motor or even really tuned a carb, so you can bet there will be some dumb questions. No one else seems to mind them. Also, nothing says that you HAVE to help me. It's totally optional for you to post back or not. I really don't care, there are plenty of people here that know what I need to know and are more than willing to help.
