Neutral Safety Switch Problems
Old Aug 21, 2006 | 05:08 PM
77f150xlt429cid's Avatar
77f150xlt429cid
Question Neutral Safety Switch Problems
I have just put a tilt column from a 78 F-150 Lariat into my 77 F-150 XLT as part of an interior upgrade and I was wondering where the neutral safety swich goes. On my strait column it was bolted to the bottom of the column. There is no place to put it on the tilt and I need to know where the factory located them in factory tilt trucks. Also the wires in thre plug are different colors, will this matter in the function of signals, fourways, or horn?
Old Aug 21, 2006 | 07:48 PM
fatherdoug's Avatar
fatherdoug
The neutral safety switch on the '78 and '79 fords attaches to the shift arm at the transmission. It also controls the backup lights. As far as the wiring, I am not familiar with that. Sorry.
Old Aug 21, 2006 | 11:04 PM
Mil1ion's Avatar
Mil1ion
This is the problem with this swap.
The wiring and harnesses.
Yes, The NSS goes to the side of the tranny.
The wiring to the NSS in 78 comes from main harness under the dash to the firewall.
You are going to need the wiring from the 78 to make it all work .
Old Aug 22, 2006 | 09:06 PM
77f150xlt429cid
I have a couple more questions for you guys, #1- will my truck start if I just tie the existing switch up under the dash? #2- Will my signals, fourways and horn still work if I just plug in the harness on the column to the one in the truck?
Old Aug 23, 2006 | 03:32 PM
77f150xlt429cid
I have the tranny out of the 78, now I need to know how hard it is to change the nss over to my 77 c6. I took the nss off but now I see that the linkage has to be changed as well, is this difficult to do? Reply ASAP thanx Chris
Old Aug 23, 2006 | 05:56 PM
Mil1ion's Avatar
Mil1ion
I searched and found this.
https://www.ford-trucks.com/forums/4...lt-column.html
MAULMAUL
Jan 26, 2012 07:13 PM
wadar1969
Nov 5, 2010 06:22 PM
Dads79
Jun 21, 2006 04:13 PM
leov5
Aug 12, 2002 07:46 PM
rick
Feb 23, 2000 10:43 PM
