Hey, i need a lil help with my tach, I know what wire goes 2 what, but I need help with hookin it up
What wire can I tie my POWER(red) wire in to so it only works when the key in ON?
Does the TACH(green) go to the neg side of the coil?
what wire do I tie my LIGHT(white) wire in to so that the tach lights up with my dash??
As for the GROUND(black) wire, can it be a chassis GROUND, or does it have to be direct to the negative of the battery??
3 way yellow connector?????????? what color wire???
the tach is strapped 2 the colomn up against the dash..........all the wires were alreay run thru one of the holes in the firewall, the tach wire i kinda figuered....thanx mil
