Better Lighting?
Old Aug 21, 2006 | 10:26 PM
hanklin's Avatar
hanklin
Originally Posted by rjmay
Will the 05 lens fit an 01?
Yes it will
For some reason Only that year will fit our trucks(01)but it`s not just the lens, it is the whole headlite,then you can add whatever bulbs you like
Hanklin
Old Aug 21, 2006 | 10:33 PM
tp_taylor's Avatar
tp_taylor
Why not go HID's. Sure, you'll **** off anyone in front of you. But if you want lighting, that's the way to go. Phillips kits for around 365 and japanese versions for 210. I have a spare set for my Volvo and may put them in the truck (have to mod a fit for different style bulb).
Old Aug 22, 2006 | 12:05 AM
fixnair's Avatar
fixnair
Smile
You guys with fogged lenses, you can polish them to look like new in just a few minutes with a product that Maguires makes. Don't remember the name but you can get it in most auto parts houses. Also if you live near a private airport you can buy a product made for lexan cockpits. They get crazed and fogged too and pilots regularly polish their windshields.
Old Aug 22, 2006 | 12:28 AM
John311t's Avatar
John311t
i thought to run the 05 headlights you need the header panel also?
Old Aug 22, 2006 | 01:54 AM
RockyMtnRanger's Avatar
RockyMtnRanger
Once you run HID's you'll never want to go back to incandescents. My wife bought a Infiniti QX4 back in 2002 that has HID's and ever since I drove it, I won't use any other type of lighting. I changed my Ranger and now my PSD. I just love the way they light up the road signs. If you have them aimed properly, they will not blind anyone. I never get flashed at, but will admit when I pull up behind someone driving a small vehicle, I turn their night into daylight. Check out my gallery if you like to see them....
Old Aug 22, 2006 | 06:59 AM
hanklin's Avatar
hanklin
No,you don`t need a header panel,it is a tight fit though,at least on my truck
Hanklin
Old Aug 22, 2006 | 10:07 AM
empiretc's Avatar
empiretc
Rocky, your headlights look like mine. I made sure to get the clear ones cuz I didnt like the blue hue. What did you pay for yours?
Old Aug 22, 2006 | 02:16 PM
RockyMtnRanger
I paid a little more then I did for the Ranger setup. Since I'm going to keep the PSD till I die, I wanted the better Phillips or McCulloch ballasts and starters. I got the McCulloch's for $335. Not much more than the cheapo's I put in the Ranger. I could tell the difference though in the quick start-up and steady light output. I highly recommend either brand.
Marty
Old Aug 22, 2006 | 10:57 PM
tp_taylor's Avatar
tp_taylor
I have McCulloch system in my Volvo and will probably order the correct bulbs for the ford housings and use the spare ballasts/ignitors. Best lighting IMO.
Old Aug 24, 2006 | 09:43 PM
sgrol's Avatar
sgrol
HID Questions
1. I see HIDs bulbs on Ebay for cheap, are these imitations?
2. How would I know if I got the real HID lights (besides cost)?
3. How long do the HID bulbs last?
4. How much do real HID bulbs cost?
Sorry if these are dumb questions, just trying to get educated. I hate my stock lights. Can drive all night on high beams and no one flashes me proving they are trash.
Old Aug 24, 2006 | 11:35 PM
RockyMtnRanger
Yep it ticks me off seeing people on Ebay selling HID bulbs for $14.95. Those are not HID bulbs. HID bulbs require ballasts to work. If the bulbs your looking at on Ebay does not have the ballasts, then they are just halogen bulbs with either a tinted glass or maybe even a special gas inside, but they still have a filament. HID's have no filaments. The light is caused by creating an arc of electricity through a nobel gas. The arc comes from the ballasts converting 12 volts to a much higher voltage. Most HID bulbs are made by the same factory, the difference in a good system and a cheapo that won't last comes down to the quality of the ballasts. Two of the better ballasts are from Phillips and McCullochs. A lot of the OEM systems run one of these. They say that the HID's last at least 3 times longer than incadecents halogens. The ones in my Ranger (cheapo system) are going on 5 years now. If you don't regularly catch air off road, you should get a good life out of them. As in my previous post, I got my complete kit for my 99 PSD for $335. You can buy a set of replacement bulbs (2 bulbs) for around $150 depending which bulbs you are using. The cheap HID kits are tempting, but believe me, on these systems, you really do get what you pay for.....
Marty
oft
Oct 17, 2014 08:46 PM
aircropsinc
Dec 23, 2012 09:03 PM
frank7mm
Nov 28, 2012 03:27 PM
eman resu
Electrical Systems/Wiring
Feb 20, 2007 08:56 PM
PA F150 4X4
Jun 2, 2003 07:01 PM
