Aerostar Ford Aerostar
Aerostar Fix
Old Aug 20, 2006 | 01:24 PM
CdnSoldier's Avatar
CdnSoldier
Aerostar Fix
Fellas
I found 2 excellent replacement door panels. But before put them on, I reenforced them by fiberglassing the corner that crack.
I will post pictures. I'm going to fix my cracked ones and keep them just incase. I know there were many that were asking how to fix them.
Old Aug 20, 2006 | 02:52 PM
96_4wdr's Avatar
96_4wdr
panel source?
Old Aug 20, 2006 | 03:13 PM
CdnSoldier's Avatar
CdnSoldier
I picked them up at a wreakers. He has about 40, from 86-97. From scrap to in very good condition, give or take the smashed in sides. One even has new Monroes. I'm getting off Monday for 5$. My Monroe shocks are lifetim, but new ones for 5$ for all 4.
Theres one, with 10Ks on the 4lt 97 motor/tranie. I'm picking out for 100$.
I've picked up a replacment Dig dash 2$, New BJs free, Alum Rims for 10$, a new unused consol 10$, I can go on and on. I have not found any good replacement Sport running boards and under body AC lines. Mine are rusted out. I have even tryed the southern states. But no go. If anyone has any good platforms, email me.
If not I'm going to build some custom platforms our of Alum.
But I have spent about 200$ for stuff that would cost 1000$
Old Aug 20, 2006 | 03:42 PM
96_4wdr's Avatar
96_4wdr
Aero gold mine up north
Old Aug 21, 2006 | 05:47 AM
aerovan's Avatar
aerovan
whoh... where abouts? i need the power window motors for both sides, and the driver side power door lock solenoid.
or i could grab both doors in good condition!
Old Aug 21, 2006 | 05:54 AM
Pablo-UA's Avatar
Pablo-UA
Who knows, what to do? My pass. door window closes very slowly and gets in stuck periodically. Motor looks well....
Old Aug 21, 2006 | 06:08 AM
tomucen's Avatar
tomucen
Pablo, I had the same thing. Roll down the window and spray the tracks (black velvet slits on each side) with silicone spray. Run the window up and down a few times and re-apply silicone if necessary. That should fix your problem.
Old Aug 21, 2006 | 06:11 AM
Pablo-UA's Avatar
Pablo-UA
It helped before.... but now - no result!
Old Aug 22, 2006 | 04:26 AM
xlt4wd90's Avatar
xlt4wd90
Pablo,
You might need to grease the steel tracks for the lifters. There is a roller on the end of the lift arm that slides back and forth in a steel channel. Pop off the door cover and see. It's really awkward to get to, and you will get grease all over your hands trying to dab into the channel.
Old Aug 22, 2006 | 06:42 AM
CdnSoldier's Avatar
CdnSoldier
Well fellas
I couldn't get my pictures to upload.
But heres how you can repair a cracked door panel.
1. Get some fiberglass
2. Fully sand down the back of the panel, where the crack is.
3. Apply the fiber glass as per instructions. note step 4
4. I put a small piece of wood dowel on the inside. To keep it from flexing. But anything would do, if it does not flex.
5. On mine, 94 XLT, my door panel was missing one of the clip inserts. This is the cause for them to crack. The door flexes and after a while will just crack. So I cut one off a old door panel, postioned it 5" centre above the last one on the back side outer edge and fibered over it.
6. No need to do anything else after, just wait and re install your panels. Unless the skinn is cracked. If so, you have to do this to a new set, or as a friend of mine did, just recover them.
It took me about an hr to do both, that is from start to finish.
I will try again to up load to steps.
Angelo190471
Oct 15, 2016 10:10 AM
ChuckDamage
Sep 19, 2012 10:07 PM
fordfan1976
May 16, 2010 01:20 AM
asavage
Aerostar
Jan 31, 2008 03:20 AM
BlueOvalFitter
Feb 14, 2004 02:31 PM
