c6 second gear
Old Aug 23, 2006 | 10:21 PM
bradb2230's Avatar
bradb2230
Can someone tel me how many turns out this screw in the modulator should be set at? I am rebuilding my C-6 right now, and sometimes, before the teardown that is, in drive from a stand still it would start in second, and sometime it would start in first. Now in an overhaul a lot of things are getting changed, I would like to have some kind of baseline to work with, If any one knows?????
Brad
Old Aug 24, 2006 | 08:52 AM
stuart1's Avatar
stuart1
Starting in 2nd is a valve problem.
It isn't how many turns out, it's how many turns in.
Back the screw out.
Now turn it in slowly until you feel the screw come in contact with the diaphragm.
Give it 2 more turns from there as a starting point.
When Ford went to a select shift transmission in 1967, 2 position was second gear.
Most other manufacturers had a 1-2 shift in that position.
Old Aug 24, 2006 | 10:18 PM
handyman43358's Avatar
handyman43358
Thank you staurt for backing me up there. I wasn't entirely sure when Ford started doing that.
Mead ex
Aug 10, 2017 09:46 PM
Joets185
Dec 21, 2015 08:20 PM
BBpwer
Aug 6, 2014 11:24 PM
Jarniscipus
Sep 24, 2010 11:09 AM
jdbanks
May 16, 2005 07:49 PM
