I.D. question
Old May 8, 2002 | 09:59 AM
Kuntryboy's Avatar
Kuntryboy
I.D. question
I'm trying to find out where I can get specs for vehicle codes on the truck I have...it's a 1965 F100 4x4 VIN listed on DMV paperwork as F11DR612772 however it has a warranty number on the inside of driverside door listed as F10JR400864 Trans A Axle 12 W.B.114 any information yall could give on what type axles , tranny, and any other specs you might be able to get out of the numbers I provided will be greatly appreciated. Thank you in advance.
Old May 8, 2002 | 10:41 AM
banjopicker66's Avatar
banjopicker66
I.D. question
[updated:LAST EDITED ON 08-May-02 AT 11:50 AM (EST)]****ryBoy:
Your DMV VIN breaks out like this:
612772 = 1965, between 580,001 - 731,999
F11 - F-100 series (not sure what difference F-10 and F-11 is, maybe 4x4?)
D - Engine Code = 352 8 cyl 2V, 172 hp@4000 rpm
R - Assembly Plant = ?
Your door tag breaks down like this:
400864 - 1963, between 325,001 and 445,000
F10 - Series = F-100
J - Engine Code = Economy 223 6 cyl 114 hp@3600 rpm
R - Assembly plant ?
Trans A = Standard light Duty Ford 3-speed
Axle 12 = Ford 9" ( I think, not sure)
WB 144 = Wheel base of 114", or a short bed truck.
Looks like you might have a swapped door, or a swapped Warranty Plate. Check on the firewall for a screwed tag, inside the glove box, or along the radiator support for another plate. You can find the real VIN stamped either on the front firewall (sometimes) or along the right frame rail, usually alongside the engine.
Sorry I cannot help more at this time!
Old May 8, 2002 | 01:22 PM
banjopicker66
I.D. question
Found some more info:
F-11 is 4x4
R plant code is San Jose
Your VIN 400864 was made in April 1963
Your VIN 612772 was made in November 1964
Hope this helps!
Old May 9, 2002 | 10:05 AM
Kuntryboy's Avatar
Kuntryboy
I.D. question
Thanks for the reply.I'm just trying to see what exactly I have in the way of tranny, and axles, etc so I can start to figure out what I'm going to do with what...if that makes any sense. It's a decently solid truck can't wait to get it in some nasty places....Thanks again..
Old May 9, 2002 | 09:45 PM
66ranger's Avatar
66ranger
I.D. question
Volume one , not the "preliminary volume" of the 1965 shop manual set will have the VIN ID codes you are looking for..
Old May 9, 2002 | 10:15 PM
63f2504x4man's Avatar
63f2504x4man
I.D. question
here ya go F11=F100 4x4 F10=F100 2wd
engine codes:
j=6cyl-223cid-1bc carb 1961-1964
a=6cyl-240cid-1bc carb 1966
b=6cyl-262cid-1bc carb 1963-1964
b=6cyl-300cid-1bc carb 1965-1966
d=8cyl-292cid-4bc carb 1961-1963
c=8cyl-292cid-2bc carb 1961-1964
n=8cyl-302cid-4bc carb 1962-1963
d=8cyl-252cid-2bc carb 1965-1966
not sure on anything else hope this helps
Old May 10, 2002 | 07:01 AM
William's Avatar
William
I.D. question
MAP37692
Dec 27, 2016 03:46 PM
belshe92
Apr 29, 2016 10:40 PM
trossol
Jun 27, 2015 02:39 PM
dohc_chump
23
May 7, 2014 04:50 PM
OldSchoolRodz
Aug 4, 2008 10:40 PM
