Steering box seal
Old Aug 19, 2006 | 05:12 PM
brian835's Avatar
brian835
Steering box seal
Greetings all! Just a quick question... On a 93 Ranger is the lower seal above the pitman arm a replaceable part on the power steering unit? If it is, any ideas where to get said seal? Thanks in advance
Old Aug 19, 2006 | 05:27 PM
matt's2.9STX's Avatar
matt's2.9STX
On an 88 Ranger 2.3, I was able to replace that while box stayed bolted to truck, but it MUST be super-clean throughout job. Of course, you can flush it afterwards. The job is no fun. Impact wrench would be nice. I got the rebuild kit at Advance Auto Parts.
Old Aug 19, 2006 | 05:31 PM
300-6cyl's Avatar
300-6cyl
Brian,
Since I happened to already have my 94 loaded in, I ran a search on it (XLT, 2WD, 4 cyl, 14" wheels)
I'm not sure exactly what position your are referring to, but Advance Auto Parts has two "Steering Gear Pitman Shaft Seal Kits" which are $16.96 and $22.74. One of these is a little cheaper at Auto Zone.
This appears to be a rebuild kit, but the website did not guarantee that the picture matched the product...
Of course, these are the prices on their website, so the prices at the store will likely vary.
Good luck!
Gig
Old Aug 22, 2006 | 10:00 PM
MazdaRangerGuy's Avatar
MazdaRangerGuy
Remove steering linkage from pitman arm.
Remove pitman arm nut.. and use pitman arm puller to remove arm.
Place drain pan under gear box
Start engine.. stop engine.. do not turn steering wheel
Pull gear box seal parts out of drain pan... there will be a seal and a couple washers.
Install new seal and washers up into gear box, in the same order they came out (unfortunately at this point it all got blown around into the drain pan when the force of the P/S fluid blew it all down.. so a manual may help here)
Reinstall pitman arm
Reinstall pitman arm nut.. torque to spec
Reinstall linkage... fill and bleed P/s
good luck!
dmccorkle911
16
Jan 22, 2016 10:39 AM
RTaylor65
Jun 20, 2013 08:43 PM
FordTrucksKickGM
Nov 24, 2008 12:22 AM
51fordfan
1978 - 1996 Big Bronco
Jul 10, 2004 11:34 PM
Forddrof
Aug 11, 2002 07:52 AM
