Sponsored by: Auxito
MAF question
Old Aug 19, 2006 | 10:13 AM
red5's Avatar
red5
MAF question
I know there is a thread on the board about cleaning the mass air flow sensor, which has been very helpful. I'm interested in doing it myself (it's never been done on my truck), but a few questions:
-can it be done inside the air intake housing without removing it?
-can someone recommend a brand of O2 safe cleaner so when I go into the parts store I know what to look for?
-any other tips would be greatly appreciated (obviously I'm not the most mechanically gifted!!)
thanks a ton!
-red5
2000 F-150 extended cab
4.6 L
K &N air filter
199,000 miles
Old Aug 19, 2006 | 03:02 PM
pilot10's Avatar
pilot10
-can it be done inside the air intake housing without removing it? - Yes, just separate the air cleaner housing and spray away. I usually spray for 4-5 seconds, wait about 30 seconds and then spray another 4-5 seconds. Puddles do accumulate but because the stuff evaporates so quickly it dries out by the time you get the housing put back together.
-can someone recommend a brand of O2 safe cleaner so when I go into the parts store I know what to look for? Buy ONLY an electronic parts cleaner that evaporates without leaving any residue- this is key. I can't remember the name of the stuff I use- It comes in a blue can. You'll be able pick some up at any hardware, auto parts or electronic store. Costs anywhere from $4-$7.
-any other tips would be greatly appreciated (obviously I'm not the most mechanically gifted!!) - Take a look at the sensor before cleaning just so you can see what it looks like dirty- If you've been running that K&N for years without cleaning the MAF it's bound to have some build-up on the filament. Also DO NOT physically touch the sensor-no toothpicks or q-tips needed. If this is the first time ever cleaning(It may have been cleaned by a mechanic if you had the truck in the shop for new plugs), you may want to disconnect the battery for a little while to force the PCM to relearn the new inputs more quickly.
I usually try and spray the MAF at every oil change. Also I clean it a week or so after cleaning the K&N so that any excess oil gets flushed out.
Old Aug 20, 2006 | 07:59 AM
red5's Avatar
red5
thanks Pilot!!!!!!!!!!!!!!!!!!
-red5
oldbird1965
1678
May 16, 2013 04:25 PM
Tylus
May 13, 2013 03:37 AM
Big Red 7.3
Computer Chips & Tuners
Aug 19, 2012 08:29 PM
Arknessee
2004 - 2008 F150
Apr 8, 2010 06:34 AM
68 250 Flareside
Jun 27, 2007 04:59 PM
