Sponsored by: Real Truck
Lift Removal
Old Sep 9, 2006 | 01:40 PM
miker67's Avatar
miker67
It is possible, though it is most likely a saggy set of springs. Measure the distance between the springs and the bumpstops and if it is only an inch or less then they are sagging. you should have at least 2 - 3 or more inches between the bumpstop and the spring. Otherwise instead of haveing a truck that bounces down the road, you will have a truck that hammers down the road. I am not sure which is worse, since i have experienced both.
Old Sep 9, 2006 | 03:48 PM
Turbo_Whistler's Avatar
Turbo_Whistler
Originally Posted by Finally
I would be interested in a stock track bar bracket and also the stock 2" rear blocks. The truck is an early '99 F250 SD Supercab Longbox Powerstroke. I have tried several salvage yards around and they don't keep these parts when they dismantle.
If your truck is an early 99 then the stock rear blocks will actually be 3" blocks, like the 350's have, but either will work.
