Sponsored by: Real Truck
Lift Removal
Old Aug 17, 2006 | 08:20 PM
Finally's Avatar
Finally
Lift Removal
I am removing a 4" suspension lift from my early 99 F250 SD. I need to know if my track bar would happen to be stock or aftermarket. Could someone give me a measurement on a stock bar? Thanks.
Old Aug 17, 2006 | 09:24 PM
MadMedic20's Avatar
MadMedic20
Should be a stock bar with a drop bracket. What make is the lift? Why are you taking it off?
Old Aug 18, 2006 | 11:23 AM
Finally's Avatar
Finally
I have no idea what kind of lift it is. I bought the truck from a dealer used and it had the lift on it.
The reason I am removing it and going back to stock is because I am tired of bouncing down the street. And yes, I am getting old.
After looking at the steering setup from my truck and comparing it to another stock truck, I believe that whoever put the lift on, didn't bother to drop the steering or the track bar. Both the track bar and the steering link bar angle upward and are not flat like a stock truck.
Old Aug 18, 2006 | 12:55 PM
bobbo7915's Avatar
bobbo7915
if you can post a pic of the track bar mounting bracket we might be able to help a little better.
Old Aug 18, 2006 | 09:42 PM
MadMedic20's Avatar
MadMedic20
I put a 4" Super Lift on my 2000 F250 about 3 months ago. I notice absolutly no difference in the ride. I drove the truck for three years stock, I drove it with stock tires and big tires, ride has always been the same.
Old Aug 18, 2006 | 10:19 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
if you need a stock panhard rod upper bracket, i have one i took off when i put on my massive Donahoe bracket. let me know if you're interested.
Old Aug 24, 2006 | 12:33 PM
Finally's Avatar
Finally
I would be interested in a stock track bar bracket and also the stock 2" rear blocks. The truck is an early '99 F250 SD Supercab Longbox Powerstroke. I have tried several salvage yards around and they don't keep these parts when they dismantle.
Old Aug 24, 2006 | 01:04 PM
bobbo7915's Avatar
bobbo7915
what do you have for blocks on the truck now? i might be interested in trading
edit: hey are those new auto meter gauges available in a 4" version
Old Aug 24, 2006 | 01:09 PM
PowerstrokeJunkie
PM me about the track bar bracket. i need to go pull it off the shelf and see about it, if you are interested
Old Aug 24, 2006 | 02:16 PM
Finally's Avatar
Finally
Are the 2" stock blocks tapered at all? I might just make them.
Old Aug 24, 2006 | 02:20 PM
bobbo7915's Avatar
bobbo7915
yeah the stock blocks have a slight taper to them.. the other optioon is to go to the stealership and order new replacement blocks for an f-250
Old Aug 24, 2006 | 03:07 PM
Finally's Avatar
Finally
I called them this afternoon. $51 for each block not including u-bolts. Which is just outrageous!! So I am going to do some measuring and put Autocad to work.
Old Aug 24, 2006 | 04:29 PM
highboy390fe's Avatar
highboy390fe
do you already have the stock front leaves if not i have some that i am willing to sell. PM me if your interested.
Old Sep 6, 2006 | 09:36 AM
Finally's Avatar
Finally
Well, I have successfully removed the lift from my truck and returned it to stock. I put on four new Monroe Reflex shocks and I cannot believe how well this thing rides. I am very happy with the results. The track bar bracket was indeed the stock bracket.
I have a question. I got the front springs from a salvage yard. They are suppose to be a code U which is what the VIN calls for. Well, the rear hangers on the front springs are cocked way back like the spring is too long. Is this normal? Also, the spring has a slight upward arch as opposed the downward arch of the lift kit spring. Is this also normal? I am sure the salvage yard springs are a little tired. But I just wanted to check. Thanks.
Old Sep 6, 2006 | 09:59 AM
bobbo7915's Avatar
bobbo7915
sounds like you have the same problem as i had before. my old springs were junk, sagging almost a full 3 inches!! the ones i replaced them with came from the boneyard aswell. so you might have just gotten a tired set.
