code 31
Old Aug 17, 2006 | 06:08 PM
ctran's Avatar
ctran
code 31
My 1988 F150, 4.9L 2WD, stick, fuel injection, has been failing the emissions test with high NO2's for the past four years.(DYNO TEST) This year same problem....scan code 31 comes up. I have changed EGR valve and solenoid, vacuum lines, air filter, oil, cap & rotor, 8mm wires, MSD 6A, plugs...etc. Still get code 31..even changed ECU today, still code 31. Haven't been back to test station yet. Any ideas??
Thanks.
email <st1:PersonName w:st="on">tranthac2000@yahoo.com</st1:PersonName>
Old Aug 17, 2006 | 08:50 PM
spike552's Avatar
spike552
I am not to familar with the codes and the memory but u could try to reset the computer i think it can be done by disconnection the battery terminal, dont hold me to this i am not sure. Hope you have better luck then me
Old Aug 17, 2006 | 09:21 PM
mississauga's Avatar
mississauga
Code 31 says that the evp circuit is below the minimum voltage. The BR/LG wire is evp signal, O/W is vehicle reference(VREF) and BL/W is the signal return(SIG RTN). Check for voltage with a digital voltmeter . With the harness disconnected , key on , check for voltage between VREF and SIG RTN. Should be between 4-6 volts dc preferbly 5 volts. If you are up to it you can create a code 35 which is the opposite of 31 , evp circuit above maximum voltage.Place a jumper between evp signal and VREF. Run the self test . If you generate a code 35 the wiring is ok.What kind of numbers are you getting for your nox and what is the limit.
Old Aug 18, 2006 | 05:37 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Sep 6, 2006 | 05:05 PM
ctran's Avatar
ctran
More codes
Thanks.
email <st1ersonname w:st="on">tranthac2000@yahoo.com</st1ersonname>
After a few days I am getting codes 32 and 41 after clearing code 31?
32-EGR pressure feedback fault.
41-(HEGO) HO2S sensor voltage low/system lean
Tom Wong, haven't replaced my CAT yet.
Old Sep 7, 2006 | 06:25 AM
albung's Avatar
albung
join the club im getting same codes and cant figure out why must be a flaw in efi i think
Old Sep 7, 2006 | 04:23 PM
albung's Avatar
albung
ford fuel injection has a egr plug for 20.00 removes egr
Old Sep 7, 2006 | 06:44 PM
ctran's Avatar
ctran
How does removing your EGR valve effect your emmissions? What other problems (if any) does this cause?
Old Sep 8, 2006 | 05:33 AM
mississauga
Removing the egr will probably raise your NOX emissions.
Old Sep 8, 2006 | 06:38 AM
albung's Avatar
albung
im not sure but when i get a chance to do it ill gladly let u know
Old Sep 8, 2006 | 07:40 AM
ctran's Avatar
ctran
Thanks, That's what I though.....I'm trying to reduce NOXs to get through emmissions.
Old Sep 10, 2006 | 12:16 AM
albung's Avatar
albung
my bad missread on emissions
Old Sep 10, 2006 | 05:02 PM
eco's Avatar
eco
A code 31 is either the EGR position sensor, wiring to the sensor, the EGR valve itself, the EEC-IV or a damaged vacuum reservoir or canister.
As far as what will happen if the EGR valve is removed or blocked off...
NOx emissions will increase
Spark knock will take place
An increase in combustion temp. will take place
Old Oct 9, 2006 | 09:32 AM
ctran's Avatar
ctran
Kimble's Complete Auto Repair in Clinton, MD is trying to RIP me off
Kimble's , is trying to rip me off.....I took my 88 F150 to them to have the oil pan gasket replaced. (typical Ford problem 4.9L) They claimed they had replaced the gasket, but there is so much oil they think it's coming from some where else???? I picked up the truck, still saw a little oil leak. It was dark and it rained all day Friday. Saturday I finally got a chance to get under there, There was oil every where.......the pan had not even been wiped off..oil leaking from the same place on the gasket. Took it back today after I had washed the underside of the truck and verified that the gasket had not been touched. Cost me over $550.00. Waiting on results.
Mr-Pipeline
Modular V10 (6.8l)
98
Sep 19, 2023 04:46 PM
Mr-Pipeline
Modular V10 (6.8l)
30
May 17, 2010 10:13 PM
dpellicone
Mar 21, 2010 08:31 PM
cadengel
May 30, 2007 08:45 AM
