Tow haul doesn't work
Old Aug 17, 2006 | 11:19 AM
Duksrule's Avatar
Duksrule
2003 6.0 auto. Awhile back the light stopped coming in but the function still worked. Now it doesn't work at all. Is there a relay in the system somewhere? Maybe bad switch? How do I get the switch out of the gear shift lever to chech it?
Old Aug 17, 2006 | 01:07 PM
Casey's Avatar
Casey
Most likely it's a broken wire in the shifter. The wires tend to break where they enter the shifter inside the steering column.
Remove the plastic cover from the steering column (there are three screws on the bottom) and you should see where the wires are broken.
Old Aug 17, 2006 | 04:37 PM
Duksrule's Avatar
Duksrule
I just went out and pulled it apart and you are exactly right. There is no way there is enough wire for a splice. Does that all come as one piece if I buy a new gearshift lever? Or is there another way to fix this?
Old Aug 17, 2006 | 06:39 PM
Maxium4x4's Avatar
Maxium4x4
What he said....mine did it also. Go to your dealer and order the part, it is the only way to fix these wires.
Old Aug 17, 2006 | 08:59 PM
Duksrule's Avatar
Duksrule
So it comes with the shift lever? What does it cost?
Old Aug 18, 2006 | 11:08 AM
Duksrule's Avatar
Duksrule
I just ordered the part from Ford. It comes with the lever, button and wires. $54 isn't bad but you would think that if this is so common, they would stock the part. Not one of the 4 dealers in town had it so it will be here Monday.
Old Aug 18, 2006 | 06:22 PM
Maxium4x4's Avatar
Maxium4x4
I don't think the wires are breaking, the shifter was manufactured with extreme prejudice....
joannev
1997 - 2003 F150
Nov 22, 2022 07:16 PM
glw165
Modular V8 (4.6L, 5.4L)
Dec 14, 2014 05:03 PM
narrowfarm
Oct 16, 2014 09:22 PM
Padra
Jun 13, 2012 10:10 PM
tompro1
Electrical Systems/Wiring
Jan 16, 2009 07:48 PM
