headgasket change?
Old Aug 18, 2006 | 11:20 AM
magnumdd's Avatar
magnumdd
headgasket change?
Ford has changed the part number on the head gasket kit that includes the headbolts three times. Does anyone know if anything in the kit was upgraded to keep from blowing head gaskets?
Old Aug 18, 2006 | 11:55 AM
npccpartsman's Avatar
npccpartsman
IMHO--if you're going that deep into the motor order the hypermax headgaskets and the headstuds. It's well well well worth the maybe little extra money you're gonna spend and dang sure worth the time involved. I have the new designed ford headgaskets on my motor cause it was warranty and they've held fine even running the bad(horrible on heads) tuner I'm running. If I had to do it out of my pocket it would be hypermax and ARP.
Old Aug 18, 2006 | 12:33 PM
magnumdd's Avatar
magnumdd
The reason I ask about the Ford kit is that my truck is loosing water and may need headgaskets. The truck is still in warranty. If the Ford gaskets are better now would I need to use the aftermarket parts?
Old Aug 18, 2006 | 12:49 PM
npccpartsman
No--in fact Ford won't unless you can talk them into letting you buy the head studs instead of the torque-to-yield bolts that ford uses.--that's the most expensive part--about 550 bucks vs 50 or 60 for the head gaskets. You don't say what year your truck is. They came with these head gaskets about june of 05, so.......
Old Aug 18, 2006 | 02:55 PM
magnumdd's Avatar
magnumdd
My truck is a 2oo3 model, with a March build date. I think the dealer will install under warranty the aftermarket studs if I purchase them. My question is are the new gaskets better than the old ones. Do I need to use studs if I am not going to do any mods to the truck? Do the new kits have better head bolts in them? I only want to do this one time.
Old Aug 18, 2006 | 03:32 PM
clevelandjim's Avatar
clevelandjim
I get the general feeling to use studs with Ford OEM gaskets or use OEM bolts with the Hypertech gaskets. Studs with the Hypertech gaskets maybe overkill.
Old Aug 18, 2006 | 04:12 PM
LVEILLON's Avatar
LVEILLON
The new design stock FORD head gasket is just fine especially for future warranty purposes. The ARP head studs would be best to go with if you are going to have the head gasket changed and the FORD tech doesn't have a problem swapping them for you.
Old Aug 18, 2006 | 06:42 PM
npccpartsman
Since it's on Ford's dime it's THEIR decision, but I would have NO problem going with the studs. After all the discussion about puking and headgaskets I don't consider it overkill--just good preventative maintenance.
Old Aug 18, 2006 | 07:02 PM
Maxium4x4's Avatar
Maxium4x4
Ford did an update on the gasket, then the head bolts. That would leave you with 3 part numbers. I purchased the upper kit which includes all the necessary gaskets you will need (around $300) to do the job. Head studs from ARP and stock gaskets (multi-layer 5) are fine for most applications. If you going for the world record using NOS, water-meth, pane and the most boost you can find....O-ring the heads.
Old Aug 18, 2006 | 07:06 PM
Maxium4x4's Avatar
Maxium4x4
the torque to yield bolts are the problem, not the multi-layer gasket. So yes on ARP studs. Hypertech is your choice for gaskets or OEM.
