cruise control doesn't work
Old Aug 16, 2006 | 09:14 PM
unger316's Avatar
unger316
what a bummer, my cruise control quit on me. What do i have to do to get it to work again?
Thanks,
Chris
p.s. 87 f150 4x4 5.0 a40d
Old Aug 16, 2006 | 10:38 PM
puck1263's Avatar
puck1263
check the fuse. Check for codes. Check the cruise throttle cable.
Old Aug 17, 2006 | 06:18 AM
unger316's Avatar
unger316
checked the fuses and they are good...wheres the cruise throttle cable located at?
Old Aug 17, 2006 | 10:31 AM
puck1263's Avatar
puck1263
On top of the throttle body right next to the throttle cable.
Old Aug 17, 2006 | 01:14 PM
87 XLT's Avatar
87 XLT
As mentioned you need to take 2 or 3 minutes to pull the codes.
If you're lucky -like I was- you'll get a vehicle speed sensor code.
30 bucks for a new sensor & my cruise control was fixed
Old Aug 17, 2006 | 02:54 PM
trgrhappy's Avatar
trgrhappy
When I replaced the engine in my 89 F159, the only hose I forgot to hook-up went to my cruise control. it's a large vacuum line that goes to a tee, then on to the vacuum tree on the intake. you might want to have a looksee if it didn't break. I'm attaching a pic of the cruise control module thing in my truck.
There ate three vacuum lines on this thing. One crosses from the top to the back of the unit. One gors to the tee on the intake. The other goes through the firewall into the cab somewhere.
Thanks,
Chris
ramhunter5877
2004 - 2008 F150
Oct 12, 2014 09:10 PM
cjcocn
15
Jun 2, 2009 06:55 AM
ccole4
Sep 9, 2008 06:04 PM
camccardell
Aug 17, 2008 08:17 PM
