Flathead Electronic Ignition
Old Aug 16, 2006 | 11:18 AM
cts1954's Avatar
cts1954
I know I can use an electronic ignition from a 318 with some modifications to fit in my 52 255 flathead, is there a prefered year I should be looking for at the local wrecking yard. Also if someone has some good detailed info I would be interested.
Old Aug 16, 2006 | 12:03 PM
dffay's Avatar
dffay
I can't help with that conversion but I believe Pertronix makes an advance plate setup for the flathead distributor. They aren't very expensive but they are highly reliable. Rotsa ruck.
Old Aug 16, 2006 | 07:38 PM
286merc's Avatar
286merc
70's thru mid 80's 318/360. I used one from an 85 Dodge 1T van; the larger series were often exempt from all the funny stuff. Be sure it is the basic distributor with only one pickup, there are different versions depending on state, EPA crap, etc. You do not want a Lean Burn either.
On vans and pickups the type is usually on the under hood decal listing tuneup specs.
86 was when many 318/360's switched to the computer and the dizzy is different.
Absolutely bullet proof, cant say that for Pertronix, etc. Get the harness, coil & resistor, and module. Some used a 2 step resistor, more voltage to the coil for starting; use the higher resistance connections.
I had a machinist friend do the conversion per Mike Davidsons book, then had it recurved for a hot 276 flathead. Dyno runs HP were still climbing at 5500. rpm!
Malvin
Flathead V8 & Flathead 6
Aug 8, 2014 12:59 PM
2zwudz
Oct 28, 2013 01:36 PM
HD74
36
Mar 22, 2009 12:21 PM
Schoonie48F2
Dec 11, 2002 04:56 PM
