Sponsored by: Innova
Replacing Rear Speakers
Old Aug 15, 2006 | 04:42 PM
nut1605's Avatar
nut1605
I was wondering if someone could tell me how to get the corner panels out of a 2007 F-350 CC so I can replace the rear speakers. Are there clips that need to be replaced or anything, or should it all pop back together. Thanks in advance!!
Old Aug 15, 2006 | 07:10 PM
FTE Trigger's Avatar
FTE Trigger
Question See if this works?
Removal and Installation -SD Rear Cab corners- Ref:01-05-4-05
  1. Remove the scuff plate.
  1. Remove the shoulder safety belt guide.
    1. Position the shoulder safety belt guide cover up.
    1. Use the Seat Belt Bolt Bit to remove the bolt.
      • To install, tighten to 40 Nm (30 lb-ft).
  1. Pull the rear door opening weatherstrips away from the C-pillar trim panel.
  1. If equipped, remove the utility trays and jack assembly.
  1. Remove the safety belt anchor.
  1. Remove the C-pillar trim panel.
  1. Route the safety belt and the shoulder safety belt guide through the C-pillar trim panel openings.
  1. Remove the C-pillar trim panel from the vehicle.
  1. To install, reverse the removal procedure.
This is from an '06 diagram (I think). Maybe its the same?? (Courtesy of Helms & Digital Dynamics, Inc.)
Old Aug 17, 2006 | 04:26 PM
CBFryman's Avatar
CBFryman
No need for rear speakers. $0.02 for decent listneing
Law for SQ.
Old Aug 17, 2006 | 06:40 PM
Nathane's Avatar
Nathane
x2, run the stock ones off headunit power if you feel the need for them, but otherwise you're wasting your money
you could put some tangband small midbass woofers in the spaces for rear speakers, and it would give you a good upgrade (they're $10-$30 each)
good luck
~Nate
Yougotthehit
Feb 6, 2011 09:55 AM
tractorfan
19
Oct 14, 2008 10:12 PM
simsnc
Jul 9, 2004 08:43 PM
greymule
Oct 11, 2002 01:42 PM
dsring
Mar 29, 2001 05:28 PM
