A Right Rear Spkr (-) Blue Purple w/ Black Stripe
B Right Rear Spkr (+) White w/ Blue Stripe Purple
C Right Front Spkr (-) White Gray w/ Black Stripe
D Right Front Spkr (+) Blue w/ White Stripe Gray
E Left Rear Spkr (-) Red w/ Blue Stripe Green w/ Black Stripe
F Left Rear Spkr (+) White w/ Blue Stripe Green
G Left Front Spkr (-) Blue w/ Orange Stripe White w/ Black Stripe
H Left Front Spkr (+) Purple White
I Amplifier Turn On Do Not Use For This Vehicle
J Power Antenna Turn On Do Not Use For This Vehicle
K Ground Wire Black Black
L Do Not Use For This Vehicle
M Dash Light Dimmer Wire Orange (if available)
N +12 Volt Ignition Wire Blue w/ Black Stripe Red
O Do Not Use For This Vehicle
P +12 Volt Battery Wire Blue w/ Red Stripe Yellow
I got a 94 explorer xlt. And when I removed the rear driver side panel and exposed the speaker. The wire colors are pink w/ green stripe and brown w/yellow stripe. I am confused. Also when place cont. tester, it registered a closed circuit. Can you assists?
well not sure about that probably easiest thing is to keep doing that and right it down or buy a haynes and make sure it has a wiring diagram in the back.
<CENTER>This code seems to be pretty common on the Internet, but I cannot vouch for it. Could your Brown/Yellow negative wire in fact be a faded pink wire with light blue stripe???
FORD Motor company
</CENTER><CENTER>1986 - 1995 All models and makes use this wire code</CENTER> Black Plug = Speaker Plug : Wht/Grn = R frnt + : Grn/Org = R frnt - : Pnk/Blu = R rear + : Grn/Org = R rear -
: Org/Grn = L Frnt + : Blu/Wht = L frnt - : Pnk/Grn = L rear + : Pnk/Blu = L rear - Grey Plug = Power Plug : Yellow/Black = switched 12v : Grn/Yellow = constant 12v : Black = ground
Also, I meant to mention that your XLT should have the premium audio system in it. If so, it has a main power amp separate from the audio head unit. (Mounted under the right rear quarter panel plastic interior trim). If this main amp is still in the car, even with the head unit out, there will be continuity between the positive and negative wires of each speaker set. The speaker wires come from the amp, not the head unit.
