Low fuel level = poor running?
Old Aug 15, 2006 | 02:42 PM
easttexasf250's Avatar
easttexasf250
Hello all, I have a 99 f250 4x4 and recently noticed that when the fuel level is below 1/4 of a tank that the truck runs very rough. The only time it does that is when the tank is below 1/4 of a tank. I have replaced the CPS in the past and I am positive it is not the problem. I wanted some opinions before I pull the tank. My first thought is that the sending unit (for some reason) is sitting high in the tank and not getting good fuel flow when the tank is low. Anyone else had this problem?
Old Aug 15, 2006 | 02:54 PM
Cuda_jim's Avatar
Cuda_jim
Check this link
http://community.webshots.com/album/32303501JuYKPH
Also at the top of this forum is a link to common mods (problems)
Old Aug 15, 2006 | 03:11 PM
PSNut's Avatar
PSNut
yup...excessive air in the fuel....bad for injectors too.
Old Aug 15, 2006 | 03:37 PM
wolftan's Avatar
wolftan
I had something similar, but there was goop in the tank and for some reason would only affect when tank was low......i dropped the tank and flushed it out and fixed the problem.
Old Aug 15, 2006 | 07:42 PM
wolfmanagh's Avatar
wolfmanagh
Here is what my little buggers looked like before cleaning them. The one is all black and the other shows some crud still. Ended up using injector cleaner to clean them. I would have done the mod that eliminates these but I didn't have the parts needed.
I also had my truck do this when I got below 1/4 tank for the first time in well over a year since I often keep it full cause it does tend to sit a lot.
Here they are cleaned up.
Old Aug 15, 2006 | 09:15 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Originally Posted by wolfmanagh
OKAY then, I'll be the first one to bite. WTH are those items and where are they?
Old Aug 15, 2006 | 09:35 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
yeah, what are those little hoojies?
Old Aug 15, 2006 | 10:03 PM
hink10's Avatar
hink10
I believe they are the screens in the mixing chamber.
edit: I would guess you have an air infiltration problem. Do the in-tank and pre-pump mods. I would get the parts for the mods if you are going to drop the tank anyway to check for crud. It's fairly easy to do. Good luck.
Old Aug 15, 2006 | 10:13 PM
k2vailkid's Avatar
k2vailkid
I second the motion...........
Tenn01PSD350
I'll buy that for a $, I guess. Don't know, took mine off. It's in a box in the shed.
Realslowww
Aug 30, 2014 09:48 AM
Lochow
Oct 12, 2012 10:26 AM
carlsson
Feb 20, 2012 05:14 AM
Arlon
Oct 5, 2007 08:00 AM
Rbuller24
15
Jun 11, 2003 06:29 PM
