Excursion Problems
Old Aug 15, 2006 | 02:36 PM
doublerafterd's Avatar
doublerafterd
Unhappy Excursion Problems
I just purchased a used (2001) Excursion, about a week after I got it the info center(Temp, Direction, Milage etc.) quit working, It will work sometimes but most of the tome it is off. I was told it would cost about $100.00 to have the diagnostic run to find the short,that does not include fixing it, Has anyone had this problem, does any one have any suggestions??
Dawn
Old Aug 15, 2006 | 05:09 PM
Monsta's Avatar
Monsta
Sit. Stay.
Have you unplugged it and replugged it back in to verify a good connection?
Old Aug 16, 2006 | 08:11 AM
doublerafterd
Where id the plug?
Old Aug 16, 2006 | 02:29 PM
Monsta's Avatar
Monsta
Sit. Stay.
Pull the over-head console down. I cannot remember if it just pulls down (with a bit of force) or if there are two bolts behind the garage door opener door thingy.
Well, not matter...you still pull it down with a bit of force. Just check for bolts first.
Once down, unplug and replug.
Old Aug 21, 2006 | 09:34 AM
doublerafterd
Thank you, I will try that
Old Aug 21, 2006 | 06:40 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Actually, it's just one tiny screw holding that thing in place. It's held up by the snaps or whatever that require some force to let go of the console.
Old Jan 1, 2007 | 11:14 AM
deshet1980's Avatar
deshet1980
did unplugging it fix it?
Excursion123
Nov 3, 2014 08:01 PM
redsnapper
Nov 23, 2011 03:40 PM
horofino
Nov 17, 2011 12:30 PM
nkenney
Nov 16, 2011 07:13 PM
Ford Excursion Owner
Jul 27, 2010 06:46 AM
