These GMC Suburbans...
Right!!............so wouldn't the statement that the military Humvees are a POS because JD Powers gave a low score on H1's, H2's and H3's be kinda ignorant??
Furthermore, I'd bet a lot of those reported problems per vehicle concerning Hummers include equipment not even on the military version.....PW/PDL/cruise/on-star/DVD entertainment equipment etc...
[QUOTE] Originally Posted by osbornk
You just have to remember that a vehicle built to military standards will be different than the one you find at your local dealer.[QUOTE]
There are not two separate drivetrains or cooling systems etc....for civilian and military use...
[QUOTE] Originally posted by Fordsflylow
If that's the case, and if one buys the jd power's 2006 vehicle durability results, then the hummers the armed services personnel are stuck using are real pos after all.[QUOTE]
Followed by this [QUOTE by DOHCMarauder] Please post a link, otherwise it just sounds like you're talking out of your fecal depositor...........you know the difference between an H1 and H2???[QUOTE]
Then this "...Civilian Hummers also include H2's and H3's.......which is what that vague JD Powers report includes. (It just states "Hummer" and doesn't break down models)..."
Does it really matter? A hummer 1, 2 or three is a hummer yes/no!?!
I posted the linky/thread, you didn't like it, and have gone off on a tangent that is going against what you originally stated.
So, where you taking this?
Back to Hummers; As far as I know, the military uses the Humvee(?) which is what the civilian H1 is based on. Obviously, the military version probably doesn't have all the bells and whistles that the H1 has. (less to go wrong??)
When I go to JD powers site specifically for the '06 H1, it shows "no data available"............hence my request for you to prove your broad generalization.
Lastly, reading that JD powers chart shows that for every 100 vehicles that Hummers have 83 more fixes.....or .83 per vehicle(that's less than 1)....a real POS
I guess using your logic, Ford must really suck when compared to all the cars ranked above them.............including Mercury.
Seein as you want to dispute the numbers, I'll bite! Ford, Lincoln, and Mercury are all above the "industry standard" set by jd power's in this study, which is 227 "problems per 100 vehicles."
Chevy, gmc, pontiac, isuzu, saturn, and hummer are all "below" the standard's set by jd powers, with hummer being the worst at 307 problems per 100 vehicles and that would be 3.02 problems per vehicle if evenly distributed. Yes/no? That would be real close to one more problem per "hummer" than Ford's "many models" under the Ford banner.
IMO Yah, that would equate to a pos in my book, but to each their own! Does that make gmc the 2nd coming in your book?
I haven't kept up, but it is a pretty different machine than the civilian H1, even when the bells & whistes are thrown out of the equation. I'm sure someone can shed more light on this.
I still have the F150, though. In fact, I plan on using soome of the extra money I make over here to make a couple of mods to it.
So, what are you saying here!?!
I'm not sure why I even try...........your lack of knowledge concerning vehicles may be too difficult to overcome.
First off, I don't even care about GM or especially Hummers but I will try to enlighten you.
The original Humvee that the military uses had the GM powertrain (both 6.5 turbo and non-turbo diesels)and little else that was GM.....I believe the company was AM General (no relation to GM)
Just recently, GM has installed the Duramax in the civilian H1....not sure on the military version
AM General then created a civilian version called the H1.......basically the military humvee with DOT safety and EPA emission compliance.
At some point, GM purchased AM General (or maybe just the rights to the Hummer brand...I'm not positive)
GM then rebadges the Suburban with some hideous bodywork and calls it the Hummer H2........a few years later they re-body the Chevy Colorado and it becomes the H3.
So to answer your question.......while GM can call anything they want a Hummer, an H2 and H3 are just rebadged and different body worked Chevies.
I've never gone against what I originally stated........The facts remain: unless you can show a report on the H1 or more specifically the military Humvee, the JD Powers report is vague at best........It's a compilation(sp?) of 3 models of which 2 make up 95+% of the total sales.
I find it comical that you "don't rely much on consumer reporting agency's, no matter the medium"..................but if it favors Ford you're all over it..
My son's best friend is in Afghanastan(sp?) as a Humvee mechanic in the Army.
When on leave, he's told me they have both the old non-turbo and newer turbo diesels....as far as injection and the like, I'll have my son e-mail him or hopefully he's supposed to be home next month.
I do know the military Humvees cannot be sold and made street legal like they used to do with the old surplus jeeps....and before the peanut gallery chimes in, it needs to be said a Humvee was designed and built first and foremost as an off-road military vehicle....the later civilian versions (H-1) had all the necessary DOT and EPA compliance.
The military version still uses the old diesel with the old 4 speed (or even 3speed, I can't recall) Auto.
The H1 Alpha (the civilian version) uses the Allison transmission.
GM doesn't own AM General, they just have bought the rights to sell under the brand name "Hummer".
So, do you come around here to attempt to dispell the belief or proof that Ford's are better. here on a Ford site
for fun, or is it some kind of a mission?
Kinda lost me on that first line...........That the Duramax is NOT in the current H1????.......or????
Thanks on the clarification on the Hummer name........the deal also included the H1 which was NOT originally a GM product.
for fun, or is it some kind of a mission?I think the better question would be just because it has a blue oval on it, you think it's the best???
I'll save my next movement for you and put a Ford sticker on it.........you can have it for cheap.
And please check my signature before opening your cake hole........I think you'll see where my loyalties lean towards..
I'm just ignorant enough to believe everything that Ford makes is the best just because.
In fact, I personally think Ford is in a horrible slump and am hoping they snap out of it soon.
It is in the civilian version - as the old diesel couldn't pass emissions.
