Coolant tempreture sensor
Old Aug 14, 2006 | 06:13 PM
eigenvector's Avatar
eigenvector
I was told that pinging can also be affected by the coolant tempreture sensor. But when looking at the Haynes manual it mentions the coolant tempreture SENDING unit - a completely different sensor. It mentions this pointedly, one drives the idiot light on the dash and the other pumps info to the computer so it can calculate mixture. But of course it only lists the SENDING unit.
So where is this thing and how would one test it - if that's even possible/advisable?
BTW: This is the for a 2000 3.0 FI
Old Aug 14, 2006 | 07:58 PM
Rockledge's Avatar
Rockledge
Follow the upper radiator hose to the engine, you'll see two similar-looking sensors near to were the rad hose connects up to the T-stat housing, the ECT is the 2-wire sensor, the temp. sending unit is the single-wire sensor.
Yes, the ECT can be tested with a simple meter: ECT Theory and Testing
Old Aug 14, 2006 | 08:14 PM
eigenvector
You know what this forum needs - an interactive engine map for people like me who just don't know #%@ but just love asking questions.
I'd be willing to help, I've asked more than my fair share of questions about everything associated with the engine except the internals. I can do all the photos and the descriptions, I just need someone to help with the mouse-overs and a place to put it.
Old Aug 14, 2006 | 08:26 PM
Rockledge's Avatar
Rockledge
Good thought, but the problem is that Ford likes to changes things around on a fairly regular basis, sometimes seemingly for no reason, so one year can be different than the next, depending on which engine it is, what year it is, etc.
The Ford Factory Manual CDs have location diagrams and such in them, among other things. You can find the manuals at Helminc.com or on eBay.
Old Aug 14, 2006 | 08:36 PM
eigenvector
I'm gonna need better probes for my multimeter - all I have are those stabber probes and working with those tiny leads on the ECT it just won't work.
The only reading I was able to get with the engine 2 1/2 hours cold was 15 ohms - or about 110 degrees. I'm not sure if that sound's reasonable given that it's about 70 right now outside. I'd better get me some better probes and then check it again after just getting in from work.
BTW: What temp does the engine typically run at? Assuming a functional but not brand new cooling system.
Old Aug 14, 2006 | 11:31 PM
Rockledge's Avatar
Rockledge
Might be better to remove the ECT and then test it while you have it immersed (along with a thermonmeter) in a pan of water. Heat the water and then watch the temperature while probing the ECT.
Old Aug 15, 2006 | 05:45 AM
Bob Ayers's Avatar
Bob Ayers
If you look at Rockledge's link, 15 OHMS is outside the operating range for a GOOD ECT sensor. I'm surprised it isn't creating an error code, and setting the CEL. Are you sure you were measuring the 2-wire sensor, and not the single wire sensor?
Old Aug 15, 2006 | 08:47 AM
eigenvector
Well.....actually I had my meter set too low and it was measuring something else. When I went back a few hours later it came back at 12 Kohms, still outside the range but I'll take Rock's advice and do the measuring from a pan of water. At least then I'll get an accurate measurment.
Hey, if I pull this thing is coolant gonna pour out of the hole? It is below the coolant hose level.
Old Aug 15, 2006 | 08:53 AM
Bob Ayers's Avatar
Bob Ayers
Yes, you will loose coolant when you pull the sensor.
Old Aug 19, 2006 | 02:54 PM
eigenvector
So I pulled the ECT sensor in my truck and tested the resistance at 3 different temps. At whatever temp cold water comes out at (I guessed 70 F) it was reading 26 Kohms, close but off according to the chart on the tech sticky. I boiled some water and measured it again it read 6 Kohms, again about 10 Kohms off for that temp, Now I've stuck it in the freezer and when I take it out I expect it to read high still, but it hasn't been long enough yet. So my question, is it normal that it reads high? When I re-install it so that when I drive over to get a replacement should I wrap it with teflon tape first or should I use something else?
So I took the ECT resistance at about 32 F and it was reading 146 Kohms - way over what it should be.
Old Aug 19, 2006 | 08:09 PM
Rockledge's Avatar
Rockledge
Without knowing the actual temperatures, it's hard to make heads or tails of the test results.
FWIW, here's another tech article on the ECT: http://www.kemparts.com/TechTalk/tt13.asp
Old Aug 19, 2006 | 08:16 PM
Bob Ayers's Avatar
Bob Ayers
As usual, geat technical references Joe!! I hope you are doing well!!!
Old Aug 19, 2006 | 08:20 PM
Rockledge's Avatar
Rockledge
I'm doing just fine, thanks Bob. Hope things are well with you, too.
