Help Identify D10E BA Heads
Old Aug 14, 2006 | 12:03 PM
serving_time's Avatar
serving_time
I have been offered a set of 351W heads casting number D10E BA. Can anyone tell me what they are off of and what comp ratio/ chamber size they are? I want to put them on a 302.
It looks like big valves, but I haven't measured yet.
Old Aug 14, 2006 | 12:53 PM
Conanski's Avatar
Conanski
They are 71 heads originally available for the Fairlane/Torino, see here.. http://www.classicmustang.com/decoding_part_numbers.htm
This will give more details on the heads...
http://home1.gte.net/res03net/faqs/head.htm
Old Aug 14, 2006 | 12:56 PM
Blurry94's Avatar
Blurry94
If i remeber correctly, a 351 uses a larger head bolt than a 302: 1/2" vs 7/16".
I do remember seeing an adapter bolt set to facilitate a 351 head on a 302.
Old Aug 15, 2006 | 06:20 AM
serving_time
Can anyone tell me what the chamber size would be?
Old Aug 15, 2006 | 07:41 AM
TigerDan's Avatar
TigerDan
Should be 60.4cc with 1.84/1.54 valves. And Matt, you're right about the bolt size. ARP has kits with special stepped washers and longer studs or bolts (depending on your preference.) The bolt kit comes in at about 100 bucks, so you have to figure that into the cost of putting 351W heads on a 302.
fordmodela
Ford Truck Parts for Sale
16
Sep 16, 2016 10:31 AM
Michae l
1978 - 1996 Big Bronco
Oct 20, 2015 08:04 PM
PA74F250
20
Sep 16, 2015 12:27 PM
corytcline
Mar 27, 2011 09:10 AM
desperado_18_2000
Jul 1, 2002 11:11 AM
