1978 - 1996 Big Bronco
help getting top back on
Old Aug 14, 2006 | 10:19 AM
69ford99's Avatar
69ford99
I'm putting the top back on the bronco but I think the front seal is in the way and won't let the top go down all the way. The first hole on each side (where the 1st short bolt goes) is raised up, does the seal need to be under the top right there or do I need to push the seal toward the inside of the truck.
Old Aug 14, 2006 | 11:05 AM
HUCKSTER-USA's Avatar
HUCKSTER-USA
there is alil lip you cap has to go ovr for it to seat properly. i used to get inside put my back against the roof lift move forward and let it down then then center bolt into the cab would be the first to go in to draw the cap tight against the cab.
Leef250
Nov 8, 2016 08:05 AM
PapaBearYuma
Oct 27, 2016 01:53 PM
Dav67Kel
Feb 8, 2015 01:29 AM
DPDISXR4Ti
13
Feb 4, 2014 09:25 PM
bronkntrukholik
Aug 21, 2013 09:42 PM
