window seals ?
Old Nov 5, 2016 | 01:55 PM
Leef250's Avatar
Leef250
window seals ?
Hey everyone,
I recently ordered up some parts from LMC and got new window seals etc. so my question is this, not sure of which part number is which now, but the window seal that goes up along the back part of the window/door and across the top of the window.. does that seal just press in or do I need to glue it in. I got the parts in the box but I don't remember any instructions for installation. Any help would be greatly appreciated.
Thanks.
Old Nov 5, 2016 | 02:11 PM
Steven@nd's Avatar
Steven@nd
Pressed in on mine. No glue.
Old Nov 5, 2016 | 03:49 PM
Leef250's Avatar
Leef250
ok thanks, any tips that will help with installing the new seals ?
Old Nov 5, 2016 | 05:06 PM
Derfus's Avatar
Derfus
Just did mine recently. If you got the vent window seal do it first once you have all the old seals taken out. As far as the lower window seals just go slow and make sure you get them popped in. On mine, the more you take them out, the less well the little clips pop in and hold. Granted I've taken them out 4 times so I can't blame them.
Old Nov 5, 2016 | 08:43 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Remove the door panel carefully. Then remove the lone bolt at the bottom of the division bar track to let the glass/fwd track have some more move around room.
X2 on do the division bar (vertical bar that is the back side of the vent wing) 1st starting at the top and work it down. Start at the top where you do not want a gap. Having not enough for the whole track will not really matter down inside the door.
Then with the window all the way down, start at the fwd top part of where the long seal will touch the division bar. Butted right up against the division bar, push it in, no glue should be required, work it in around and starting down and then start the very end of the seal and carefully pull it down the long back side track by reaching inside the door.
Make sense? Also grease the regulator and the bar that the plastic wheel rolls in at the bottom of the window.
Use masking tape on both sides of the door/glass edge is you are replacing the anti rattle strips to prevent tool scratches.
LMC seal are junk IMO, JBG is way better and that is what I use.
Old Nov 6, 2016 | 05:43 AM
jaleus's Avatar
jaleus
Recently did my '74. Toughest part was getting the old brick hard window run felt out. I'm not satisfied with the fit on the outer beltline weatherstrip. JBG was mentioned over LMC. Who is JBG?
Old Nov 6, 2016 | 07:07 AM
77&79F250's Avatar
77&79F250
A FTE sponsor at the top of the page.
JBG or BG='s Jeff's Bronco Graveyard, or just Bronco Graveyard. Early Bronco Restoration Full Size Bronco Restoration Classic Ford Bronco Parts For Sale
You do know that 78/79 Full size Bronco's have pretty much the same interior,front clip and doors as our trucks. Same front suspension as 4wd 1/2 ton F150.
The environmental control panel has a rear window roll down switch, instead of a tank switch. Bronco's also come with OEM bucket seats and a center console that will work in our trucks.
Old Nov 6, 2016 | 11:07 AM
PapaBearYuma's Avatar
PapaBearYuma
Bronco Graveyard has house-brand rubber that seems "good-enough". I recently did the copper truck with JBG rubber. They also carry Dennis Carpenter rubber, and it is slightly less expensive than just getting it from DC. I used DC Rubber in the yellow truck. Very nice-still perfect after several years
Old Nov 6, 2016 | 01:05 PM
Leef250's Avatar
Leef250
thanks for all the help guys.
Old Nov 6, 2016 | 03:36 PM
jaleus's Avatar
jaleus
So here is the part I don't like, that contour of the piece does not agree with the door. When installing the hole the last clip agreed with did not seem to be in the same orientation. Did I miss something, after the fact thought maybe a person is supposed to cut reliefs in the metal and shape it to the door. Is what BG selling a better fit. Thanks for any insights.
Old Nov 6, 2016 | 03:57 PM
PapaBearYuma
The DC anri-rattlers fit better than the others, but are more expensive. Also, it seems the inner and outer panels of the door are slightly different, so you might try moving the ill-fitting part to the other door
Old Nov 8, 2016 | 05:41 AM
TwoTone250's Avatar
TwoTone250
I just did mine yesterday and used these videos as reference. Just be careful around you window and paint.
Old Nov 8, 2016 | 08:05 AM
CelticOne's Avatar
CelticOne
Regular User
Great videos. Thanks
MontanaboyDesigns
Aug 15, 2016 10:05 AM
ZombieSlayer
1978 - 1996 Big Bronco
Feb 11, 2015 10:11 PM
F-100CustomCabTBC
Mar 9, 2013 06:43 AM
yankeerebel
May 2, 2010 03:51 PM
