Sponsored by: Auxito
engine swap
Old Aug 14, 2006 | 04:50 AM
metmag52's Avatar
metmag52
engine swap -- 4.2
First time on the site--looks interesting-- I have a 1997 f-150,2 wheel drive,4 speed with the 4.2 v-6. Engine is blown!! Is there another engine or engine/tranny combo that I can put in without needing a degree in rocket science???? Just scimming through some of the site and found that the 302 has the same block?? Does that mean a 5.0 from any full size car would fit?? If I did that ,what about the computer? Thanks
Old Aug 14, 2006 | 05:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Aug 14, 2006 | 01:59 PM
AlfredB1979's Avatar
AlfredB1979
Um, no, the 302 isn't the same block.
You *might* be able to swap in a later Exploder 302 with auto tranny in structural terms, and since that setup is also OBD2 like yours, that is helpful, but even factory F150 options like the 4.6 or 5.4L are work...and they would just drop in with the right pieces to go with them.
You would need all the associated electronics with any of the mentioned engines...
Old Aug 14, 2006 | 05:21 PM
steve(ill)'s Avatar
steve(ill)
save your money, sell that truck and buy a 2001-2002.
