Working GTG
Old Aug 23, 2006 | 07:20 PM
  #31
MAKO314's Avatar
MAKO314
bunch of guys all working on a FOUND ON ROAD DEAD, might want to buy the wife and kids some earplugs just for good measures
Old Aug 23, 2006 | 07:31 PM
  #32
SuperSnake's Avatar
SuperSnake
Which day??? Sept2nd or Sept3Rd
Old Aug 23, 2006 | 07:39 PM
  #33
MAKO314's Avatar
MAKO314
no matter here whenevers fine for me
Old Aug 24, 2006 | 01:16 PM
  #34
SuperSnake's Avatar
SuperSnake
Let's Make it Sept.2nd.
I got the adapter plate,timing gear chain set and overhaul gasket set today.
Which RTV do I need to get? There is more than one that gets used right?
Old Aug 24, 2006 | 01:38 PM
  #35
SuperSnake's Avatar
SuperSnake
If someone has the time would you make print copies of these links? We'll need them to reset the timing. Thanks
https://www.ford-trucks.com/forums/4...ht=timing+gear
http://www.reincarnation-automotive....son-index.html
Old Sep 1, 2006 | 07:19 AM
  #36
79 Trailer Special's Avatar
79 Trailer Special
If you got a aftermarket performance timing set you wont need the printouts. I think I read somewhere ya got a cloyes double roller setup so it wont have the retard built in, normally there will be a selection for 4 retarted, straight up and 4 advanced so going straight up will do the same as going with the early factory set.
A gasket set, rtv,gear puller for the crank gear, some anti freeze and stuff for an oil change should be all ya need for the timing gear change. Belts and hoses can be looked at while its getting done. Ill have some basic hand tools with me. Ill PM ya my number so give me a call tonight after 7 to work out times and details.
wrd0225
Sep 30, 2014 10:53 PM
dbag
Aug 9, 2012 07:16 AM
ubereal2
Missouri Chapter
13
Apr 16, 2008 07:24 AM
biohazardbill
Sep 30, 2007 04:03 PM
SuperSnake
North Carolina Chapter
Oct 9, 2006 02:24 PM
