My edge put up a dtc alert code 4 so i checked and they were,B1600,B1601,B6012 and B2431 dose anyone know what they mean? i just put in a alarm could they be related?
B1600
PATS Ignition Key Transponder Signal Is Not Received
B1601
PATS Received Incorrect Key-Code From Ignition Key Transponder
B2431
Transponder Programming Failed
i can't find b6012 and looks like you had a remote starter installed too....
pats is your security feature that works with your key, since you installed a remote start, it's bypassing the system....now the pcm computer thinks that you inserted a incorrect key..and is able to start...
