I would like to get reccomendations form you guys that are using an inverter. I would like to know what I should look for before buying one, watts, etc.
One thing I discovered is that the higher wattage inverters usually need to be conencted directly to the battery. Makes sense when you figure the current draw is roughly Watts/Volts. So if you have even a modest inverter like my 400W model, you could be pulling about 30 Amps. Some lighter sockets are fuesed to only 5-10 amps or so. Mine says use lighter plug only for up to about 100W.
A cell phone pulls very little power. A laptop could pull a few hundred watts if the battery is low.
I used to use a 150 watt inverter for my laptop and inkjet printer, it worked well if the laptop battery was fairly well charged but when it needed to be charged and used at the same time it struggled and beeped. I replaced it with a 400 watt and it does every thing I need it to.
