66' engine,tranny,Transfercase, combo prob
Old Aug 11, 2006 | 09:02 PM
offroad72's Avatar
offroad72
I have a problem I need help solving. I have a 66' f-100, short bed, four wheel drive. I am turning it into a pre-runner. for all you non off-roaders its a truck you take out to pre-run the race course. I am having a problem with my drive train. The truck has a 352. which I am not sure If I am going to keep in there or put a 390 in it. doesnt matter either way. I am planning on taking the old Manual Tranny out and putting a C-6 under it. But my problem is the transfer case. of course it still has the original 4-wheel dirve/2-wheel drive case in it. (sorry I dont know what the name or number is of it) I dont think it will bolt up to the C-6. and I realy dont want to put a newer motor in it. So what can i do. is there another Transfer case that will work with the 352/390, C-6 converstion. I dont care if its a newer Transfer case. any help would be great, thanks.
Doug
Battle Born off-road racing
Old Aug 12, 2006 | 05:43 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
what 5 spd manual trans was available
Old Aug 12, 2006 | 05:52 AM
jowilker's Avatar
jowilker
Doug, Welcome to the nations truck stop
You will need to find a C6 that will bolt to a FE engine and a transfer case that will fit the C6.
Some of our 4X4 posters should be in shortly.
John
Old Aug 13, 2006 | 12:11 AM
offroad72's Avatar
offroad72
I have a C6 that will bolt up to an FE. not a problem there. its the Tranny case thats giving me fits. the C6 is to long or somthing. cause the original Tranny case wont bolt up to it. I am just looking on what I can do about that. mabay a diffrent Tranny case. probably newer. or mabay even a diffrent Tail shaft for the C6. I just need the right combo is all.
Doug
Battle born off-road racing
Old Aug 13, 2006 | 12:17 AM
offroad72's Avatar
offroad72
as for the question that Lamkin asked. I dont know if there was a 5 spd available back then. could be wrong. My old truck just has the old 4 speed manual in it right now. thats what I am looking to take out, to replace it with the C6. it wouldnt be a big deal if I didnt care about the 4-wheel drive. but I want to keep it in there.
DOug
battle born off-road racing
Old Aug 15, 2006 | 03:16 AM
iontkendall's Avatar
iontkendall
I have a 66 Ford 4x4.It originally came with a 352/390,4 spd granny gear trans and single spd transfer case.It now has a 428,c-6 and a 2 spd transfer case.You can use any transmission/transfer case from any truck that came with a 352/390 engine.Your options are;4 spd or c-6 trans that is "married" to the transfer case(that means it is directly bolted together) or 4 spd or c-6 that is "divorced" from the transfer case(that means there is a drive shaft connecting the two).Hope this helps.
Old Aug 15, 2006 | 08:24 AM
PROSTOCK's Avatar
PROSTOCK
offroad...IMHO the C-6 NP(New Process) 205 is about as good as it gets reguardless of the motor. I ran that combo for years and failed to blow it up...U-joints and driveshafts are another story.
As mentioned the C-6 needs to be for an FE, no others will fit an FE. To mount the 205 to the C-6 you remove the tailshaft housing and bolt up the 205. The 205 you're looking for will have a special, Ford housing to allow fitment to the C-6. There might also be issues with tailshaft length, I cannot remember. You can also easily convert(twin stick conversion) the 205 to allow 2WD low, which I found very handy.
FE/C-6/NP 205, DANA 60 w/lockers front and rear and your good to go!
Old Aug 15, 2006 | 05:00 PM
offroad72's Avatar
offroad72
Thanks Prostock and Iontkendall. this helps out a ton. Looks like I am almost there. I have the FE C6, the Truck has a Dana 60 Rear and Dana 40 front. (just need the lockers.) now all I need to get is the NP 205. thanks again.
Doug
Old Aug 16, 2006 | 09:23 AM
PROSTOCK's Avatar
PROSTOCK
Go easy on that Dana 40 front. I have actually stripped the teeth off the pinion when stuck. Fortunately pre-running usually doesn't require 4WD.
Old Aug 16, 2006 | 04:47 PM
offroad72's Avatar
offroad72
Exactly. I dont plan on using 4WD while pre-running. I actually would prefer to not have 4WD at all. but the truck has been in the family since the early 70's. So I told myself before I started the project that I wouldnt cut it up to bad. I want to give it some nice suspension but nothing to radical. Roll cage but nothing supper. keep it original in state with some steroids added.
Doug
Trailerpark
1983 - 2012 Ranger & B-Series
Jul 10, 2016 11:30 PM
krazytrain
Jun 28, 2015 03:34 PM
santi2322
Nov 21, 2009 02:33 PM
Judson4.9L
Jun 13, 2005 08:42 PM
skonnie-mark
Sep 9, 2004 06:55 AM
