Temp gauge pin below normal
Old Aug 7, 2016 | 09:24 PM
Ford4you's Avatar
Ford4you
This past weekend I put about 160 miles on my 87 f.150 with the 5.8 L 351 W and it is the most highway miles I have put on since I bought the truck last summer from my neighbor for $300. I noticed the pin on the temp gauge spiked to between the N and O in the NORMAL range and every once in awhile it would drop down below the NORMAL range. Do you think my themostat is stuck? When I got home tonight I popped the hood and touched the upper radiator hose and it was hot. Any recommendations?
Old Aug 7, 2016 | 10:05 PM
DieselCamper's Avatar
DieselCamper
I wouldn't trust it. It's an idiot gauge and nothing else, as long as it's not on the c and not on the H, don't worry about it.
Old Aug 9, 2016 | 10:10 AM
choate's Avatar
choate
mine does the exact same thing. same engine as yours too
Old Aug 9, 2016 | 11:33 AM
Ford4you's Avatar
Ford4you
I replaced my thermostat last night and it still does it. So it has to be running just fine just the gauge is alittle off. As long as it's not in the cold or in the hot I'm gonna drive it as is.
Old Aug 9, 2016 | 01:22 PM
sgip2000's Avatar
sgip2000
Have you replaced the sensor?
Old Aug 9, 2016 | 05:35 PM
Eddiec1564's Avatar
Eddiec1564
2X on the gauge temp sensor.
My 89 does the same thing even after a cluster swap to a fresh looking cluster. Now I just have to crawl under the I6 engine manifolds to change the temp sender.......
Old Aug 13, 2016 | 10:02 PM
Ford4you's Avatar
Ford4you
I have not replaced the sensor, but I suppose that would be my next step.
bowhunter96
Sep 15, 2021 07:05 AM
dustyroad
Sep 29, 2018 07:38 PM
flashback max
Jun 27, 2011 11:22 AM
will
Sep 21, 2004 04:00 PM
1explorer
Feb 5, 2003 06:03 AM
