HELP - indicator light on OD switch is flashing
Old Dec 5, 2003 | 09:38 AM
Jimmie's Avatar
Jimmie
Help
I have a 95 F250 4x4 Power Stroke with auto trans. When I got in it this moring and started it up, the indicator light on the overdrive switch (on shift handle) was flashing on and off. It is snowing here (8 inch) so I had put the truck in 4 wheel drive when I noticed the light on the shift handle was flashing. Taking the truck out of 4 wheel drive does not stop the flashing, nor does pushing the button at the end of the shifter. I suspect the light was flashing before putting the truck in 4 wheel drive and I didn't notice it. The flashing is steady with no difference in timing.
Any Help would be appreciated.
Jimmie
Old Dec 5, 2003 | 11:16 AM
jim henderson's Avatar
jim henderson
the flashing light means the sensors have detected a problem in your tranny. You will need to pull codes from the computer before you can start diagnosing, unless there are other obvious symptoms.
Get a dealer, a parts store, a buddy or yourself to pull codes.
Locally Autozone will pull codes for free.
Good Luck,
Jim Henderson
BenFranklin
6.2L V8
18
Dec 23, 2025 07:03 PM
johndem
Oct 13, 2024 10:09 PM
Ziob
Nov 29, 2019 07:37 PM
n20
18
Dec 29, 2010 11:33 AM
Thudpucker
1997 - 2003 F150
Aug 30, 2009 10:29 AM
