Rear end locked up??? help..
I posted this question in the axle section but got no replies after 3 days.
Drove 20 minutes to where I was headed to. Got there and everything was fine. Unloaded truck, about 15 minutes, and when went to leave truck wouldn't move. Got truck to crawl in 1st gear and Reverse. Limped it to a repair shop near by where we jacked rear end up. Both rear tires were locked tigh even after backing the shoes off all the way. I started the reuck up on jack stands and put it in first gear. THe driver side tire spum but as soon as I put the clutch in the rear tire stopped instantly.
Got towed home and afte rthe truck sat (detween waiting for the tow truck and the ride home) about 1.75 hours the truck roleld freely down the driveway with just the clutch in.
am I thinking correct in that I have at least one bad bearing in the rear end or could it be somthing else???
After the truck sat for about 2 hours the rear end was no longer locked up.
The odo reads 42K but is most likely 142K or maybe even 242K. I do know the truck sat for about a year (mayby a little over a year) before I got it. I watched it sit as I passed it avery day to and from work before I decided to stop and take a look at it.
I bet 10 to 1 the hot drum was right rear, was the parking brake adjusted correctly and the spring on th shoe linkage retracting the cable completely?
This is another known problem. At the E brake cable split, one into 2 cable I have found it better to run two of those long springs that help the cable to return, less chance to drag a shoe.
.....=o&o>.....
I did not change the master cylinder.
It was the left rear that was 230 degrees.
I also thought about it and after the rear shoes were backed off the rear tires were able to be moved by hand but were still really tight.
They are drum all around and power.... So power drum..... It has the large round vaccuum thingy(brake booster) behind the master cylinder.
So your saying my whole problem might be a $20 master cylinder?????
You may have the fluid return port blocked off, booster plunger too long to not allowing fluid to return into the MC. This plunger has an adjustment to make longer or shorter. You need to check that the ports (front and rear) are open before the pedal is depressed. With a slight plunger movement it should close off the ports front and rear to create pressure in the brake system.
Another thought, is that MC a rusty sludge mess where the small fluid return ports are plugged up with crap preventing fluid return?
.....=o&o>.....
Well I'm still a rookie at some things. Changinf a MC is no problems but checking and testing. Well besides requiring some brains requires some know how. What will I need to look at and/or for to see if the ports are correct or should I just not play with it and just replace it. Could I rebuild it or is the MC like the brake pistons and new ones are $1 more than a rebuild kit? I know a new one is only like $20 but if a rebuilt kit is $5 thats like $15 saved so I can start the truck
(you know turn the key and the FE drinks 3 gallons
). J/K I don't even think about gas for this thing because if I did I'd....... I don't know what I'd do.....I also want to make sure it is the Mc and not really the bearings in the rear because I don't wanna get stuck again durring my test drive.
And you said somthing about the booster plunger. Where is that adjustemt?
I'm still learning here and probably still will be learning 20 years from now.
Thank you for everything so far...
Are you sure the E brake is adjusted correctly and is releasing completly, your not dragging the E brake shoe are you?
This is one reason I rarely use the E brake besides having two springs at the cable split to help retract the cable.
.....=o&o>.....
It may include your truck as well.
http://www.clubfte.com/users/mil1ion...trations2.html
Thing that puzzles me is nothing was changed on that trucks MC and booster and now he has problems. Hope he gets is squared away before it becomes reply number 50.
.....=o&o>.....
Right now I have 2 trucks down.
My (insert foreign brand here starting with T) got denied inspection due to oil leak and that has turned into a head gasket repalcement. That head gasket repalcement turned into a 2nd head gasket replacement. Hopefully it wll be done tonight and I can move onto the '68.
Having 3 hours a day (Mon-Fri) makes it tough to get things done.
And thank you for the diagrams. I've changed out MC before but never had to play with the plungers. Just drain unbolt, rebolt and fill. It was also 80's F-series
