I have a 1976 that needs new hinge pins. I have found a donor set of hinges with good pins I could use but does anyone know where I could go for new ones? Or what other makes and years (ford products) that might work for the truck.
I have checked a couple of the sponsors and the only go back as far as 1980. I will try a few more??
I will look at H.E.L.P tonight. Forgot to check there thanks. If you look at the 1980 ste they look exactly the same in the picture. i do not know if they are the same in size and length however.
