timming or carb help???
Old Aug 9, 2006 | 05:27 PM
f-4x4's Avatar
f-4x4
ok ive got a 78 f-150 4x4 4speed.
i rebuilt the 351m to stock specs exept for a rvtype cam and edelbrock intake and a 670 truck advenger.
the truck runs great but if you rev it up from idel a few times in will back fire out of the carb slightly, also when going up a sligh grade doing 50mph or so it stumble a little.
can any help me remodie my problem.
thanks matt
Old Aug 9, 2006 | 08:27 PM
mark a.'s Avatar
mark a.
Did you check lifter preload ?
Old Aug 9, 2006 | 10:17 PM
f-4x4's Avatar
f-4x4
no I did not, how do you do that and is it to late
Old Aug 9, 2006 | 10:53 PM
53fatfndr's Avatar
53fatfndr
The easiest thing to do first, would be to check the timing and then go from there.
Old Aug 18, 2006 | 09:50 AM
2classics's Avatar
2classics
backfire sounds like timing
stumble might be a power valve in the carb.
Old Aug 18, 2006 | 05:40 PM
rchewitt50's Avatar
rchewitt50
thanks matt
What cam did you use? lifters new?
Old Aug 19, 2006 | 12:48 AM
roger dowty's Avatar
roger dowty
yea- almost like an exhaust valve seating issue...maybe...hopefully not. also check floats and ignition system.
Old Aug 24, 2006 | 05:37 PM
2classics's Avatar
2classics
There is a way to check valves with a vacuum guage. Can't remember how, but somebody here probly knows.
Old Aug 24, 2006 | 06:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
For vacuum gage readings and other information check my web page (click on the spinning wrench) and:
http://www.clubfte.com/users/torque1st/index.html
http://www.users.bigpond.com/ergoff/vac1.htm
For carb help check out the carb forum:
https://www.ford-trucks.com/forums/forum72/
