Oil & Lubrication
Fluids
Old Aug 9, 2006 | 03:48 PM
Mater64's Avatar
Mater64
Fluids
My dad gave me a 64 F-100 a couple weeks ago. I've noticed that I may need to add fluids. I want to keep my truck in the best shape possible. The truck has about 70,000 original miles. Both engineand tranny are original. I plan on using 5w-30 in the motor and 80w-90 in the tranny. Would these fluids be ok? Would something else be better in either? Also what brands would you suggest I use?
Mater
Old Aug 11, 2006 | 08:35 AM
green 1969 f100's Avatar
green 1969 f100
Mater
I have used Motorcraft,Kendall GT-1,Havoline, Mobil, and Pennzoil 10w30 oil with Motorcraft, Purolator, and Wix Filters in my 1969 F-100 360 engine for 134,000 miles without any problem. You can expect numerous opinions on the brand and weight reccomendation. The main thing is to use a SM quality oil and a good filter (NO fram) and change them regularly. 6 months or 6000 miles was the original reccomended interval which I use since mine is no longer a daily driver. If your transmission is a manual, the 80w90 should be fine. During my youth I worked at a full service gas station and serviced several mid 60's to mid 70's vehicles and we always used 80w90 gear oil in them. If your transmission is automatic the only choice is ATF Type F.
Old Aug 11, 2006 | 01:51 PM
Mater64's Avatar
Mater64
Thank you very much the the info. I'll keep in all in mind.
Thanks
starwriter
Jan 28, 2008 02:12 AM
skunk250
Nov 18, 2007 01:52 PM
Mater64
Nov 1, 2006 01:15 PM
Mater64
32
Aug 26, 2006 12:24 PM
Mater64
Aug 14, 2006 11:39 PM
