Where to look for an E4OD replacement
Old Aug 9, 2006 | 03:12 PM
true blue's Avatar
true blue
I know the time will come. Where do I want to go for a good transmission replacement? I will keep an automatic.
Old Aug 9, 2006 | 06:27 PM
trike1946's Avatar
trike1946
I just get the one in there rebuilt. There are places to order them. Try our sponsors.
Old Aug 9, 2006 | 06:50 PM
true blue's Avatar
true blue
Is it best to just go to Ford? I know it will probably cast more but I have had bad luck in the past with transmission shops.
Old Aug 9, 2006 | 07:05 PM
f350duallyguy's Avatar
f350duallyguy
I had mine replaced at the dealer,it will cost a little moe but if they install,you get 3yr/36K warranty
Old Aug 9, 2006 | 07:26 PM
94_turbo's Avatar
94_turbo
guy that rebuilds trans--and works at ford--said ford rebuilds are trash--bts=brians trans shop--out of lead hill,arkansas----jon faubion--out of ok--suncoast trans--john wood out of ca---
Old Aug 9, 2006 | 07:42 PM
79f-250custom's Avatar
79f-250custom
jasper engine and tranny repiar. good place.
Mitch
Old Aug 9, 2006 | 07:51 PM
trike1946's Avatar
trike1946
If you plan on towing a lot, you should not go to Ford. They rebuild with stock parts. You need heavy duty for towing. You should get the sonnax kit, and replace the stock aluminum planet gears and ring with steel, etc. There are other upgrades you can get. Ford designed the trans to shift without the truck shaking. They do it buy having the trans slip a little when it shifts. If you are towing anything heavy it will fail. If you are just riding around, Ford is probably fine.
Old Aug 9, 2006 | 08:39 PM
helifixer's Avatar
helifixer
just don't buy off of e bay and in NO WAY make any deals with phoenix re trans, phoenix hard parts or what ever name yhey are operating under today.
Old Aug 10, 2006 | 09:27 AM
true blue's Avatar
true blue
Funny you should mention that. I was just looking at them last night.
Old Aug 10, 2006 | 10:13 AM
bodabdan's Avatar
bodabdan
Veteran: Navy
I strongly second helifixer. I have had a bad Phoenix experience and I won't refer anyone to them, ever.
Old Aug 10, 2006 | 02:33 PM
true blue's Avatar
true blue
I appreciate that input. I will no longer look in their direction. Thanks!!
Old Aug 10, 2006 | 02:37 PM
1997F-350's Avatar
1997F-350
look no further than 1 of these 4 anything else is just a waste of 2500 bucks because sooner or later it will need it again. my .00002
these are the e4od/4r100 experts and built to last
Old Aug 11, 2006 | 11:09 PM
Gene W's Avatar
Gene W
I don't know if all Ford dealers do this or not but my local dealer offers the so called Ford rebuilds and also the Jasper rebuilds. The Jaspers cost a little more but have a better warranty as I recall.
You can also buy the Ford rebuilds over the counter and install it yourself but not so with the Jasper.
Gene
BluePitt
34
Jan 9, 2012 06:52 PM
Saxon
Jul 7, 2008 05:55 PM
fderflinger
Oct 31, 2007 08:30 PM
Highmark18
May 1, 2007 02:24 PM
87rustbucket
Appearance & Dress-Up
Nov 15, 2004 10:13 PM
