1978 - 1996 Big Bronco
Upper Ball joint blues
Old Aug 8, 2006 | 10:07 AM
My96Bronco's Avatar
My96Bronco
Question Upper Ball joint blues
OK here goes I am new to this but not my 96 Bronco.
Replacing upper ball joints and have a problem.
I CAN NOT REMOVE BALL JOINT.
It looks like the Camber adjuster is rusted to the ball joint
I have used forks to break loose, to the point of the ball seperating from its
housing. Great now the steering knuckle is out of the way.
Anybody have an idea.
Old Aug 8, 2006 | 10:43 AM
cje07's Avatar
cje07
I do not remember on that model if you may require a ball joint press? Did you try heating it up with a torch and then breaking it loose? Do you have pictures you can share with us?
Old Aug 8, 2006 | 11:49 AM
andym's Avatar
andym
I think he's trying to get it off the knuckle.
The camber adjuster should be stuck to the axle housing, not the upper ball joint.
You loosened the lower ball joint nut too, right?
Old Aug 8, 2006 | 02:11 PM
My96Bronco's Avatar
My96Bronco
OK how do I add the pictures?
Old Aug 8, 2006 | 02:48 PM
cje07's Avatar
cje07
Do you have a place to host them on a site such as superford.org? If so all you would need to do is right click on the picture, select properties and copy the address (URL). Then get into this thread, click respond and click the Insert Image button (Mountain with the sun) icon. Paste the image into the popup and post the thread. Let me know if you need anymore help.
Old Aug 8, 2006 | 03:38 PM
My96Bronco's Avatar
My96Bronco
OK I figured out how to make a Gallery.
So if you click on
my96bronco
then view gallery
you will see my Ball joint blue album of pictures
Thanks for the help!!!
Old Aug 8, 2006 | 07:20 PM
andym's Avatar
andym
Holy crap, dude. How did you get the ball out of the joint? It's not supposed to come apart that way.
Here's what you do. Take the castle nut and put it back on the ball joint stud. Then beat the snot out of it with the biggest hammer you can find. A 5lb or so usually works best. If you don't put the nut back on, you'll mushroom the threads out, and you'll have an even harder time getting it apart.
Old Aug 8, 2006 | 08:49 PM
Hobgoblin's Avatar
Hobgoblin
you need to get the camber bushing out by pushing it UP. Grind a flat on the ball joint ball and set up the press just like you would to take the ball joint out of the knuckle. The mushroomed stud won't come out of the camber adjuster, so it will have to come out of the axle housing. you need a ball joint press at this point. a big hammer will most likely bend the axle housing before the camber bushing pops out. They are only about $50. I've seen alot of them seperate like that.
Old Aug 8, 2006 | 10:25 PM
gman88's Avatar
gman88
I used a pitman arm puller (had to custom grind slightly to get the width needed) to pull the factory camber bushing out. Use lots of PB Blaster or equivalent.
sam hain
1997 - 2003 F150
May 23, 2025 11:39 PM
briangelc
Jan 4, 2020 08:37 AM
colin1966
15
Oct 23, 2016 08:36 PM
fubar25827
Apr 29, 2012 06:45 PM
Eaglefixer
1983 - 2012 Ranger & B-Series
Mar 1, 2010 06:15 PM
