Running hotter than normal
Old Aug 7, 2006 | 03:48 PM
rguidry's Avatar
rguidry
My stock 96 f-250 has started running hotter than it used to. Driving in town or at highway speeds the needle on the stock guage is on the "R", this is with the truck empty. Towing my 9500 lb travel trailer at 65mph the needle is just past the "L" which worries me. I've flushed the radiator, replaced the temp sensor and the thermostat and the fan clutch appears to be working properly. Any suggestions?
Old Aug 7, 2006 | 08:51 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Can you hear the fan locking up? When it is in direct drive it howls loudly. If you can't hear it running with the temp up that high I'd suggest the clutch may be the problem.
Old Aug 7, 2006 | 09:55 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
Flat down the highway while pulling a load should it still go on? you got a 65mph wind blasting in the rad.
As for your engine, running hot, if your clutch fan does operate with the howling like cookie said. I;ve seen this twice but may not necessarly be your problem, I've seen the impeller on a water pump lossen on the water pump shaft. So the impeller would still spin but slip on the shaft which does'nt give you the flow required. If the fan clutch turns out to be OK, I know its alot of work but maybe pull of your waterpump to inspect it, if that turns out to be good then just use a little silicone and install it back on again. I've never took my water pump or seen a psd water pump off so I dont know if its a press fit on the shaft but cant see why not.
Hold up and let a few more people chime in
Old Aug 8, 2006 | 06:29 AM
tjbeggs's Avatar
tjbeggs
also chech the upper hose when the truck is hot to see if the upper hose is hot. if its not you have a malfuncting thermostat. also everyone of us should have a real temp gauge in our truck instead of the junk stock guage that has us describing our engine temp with n-o-r-m-a-l's. i put an autometer temp guage in and its a welcome releif to know exactly how warm my engine is. I have heard of many who really are over heating and the guage never told them that.
Old Aug 8, 2006 | 09:30 AM
DAVID'S97F250HD
Also, new thermostat or not, I've seen new ones fail. If thier difficult to replace I throw them in a pot of hot water with a temp gauge over the stove and check to see how thier operating even if thier new out of the package. Also make sure your resivoir cap is functioning good., thery thats our rad cap
My friend spent 2 weeks on his Volkswagon van with the rear engine flat 4 cylinder in the back, he did everything from changing the hoses, to rad, to pulling heads off thinking it was a internal problem. The new thermostate was no good.
Old Aug 8, 2006 | 06:01 PM
MattB_1442's Avatar
MattB_1442
Ditto that - putting in a REAL temp gauge. I'm glad I did. It identified that I was running way to cold - 180 degrees most of the time.
I changed out the t-stat for a 205 from Dieselsite - now the glorified idiot gauge reads at the "R" @ 205 degrees. It was running @ the "N" and the real gauge read 180.
Not sure if this helps any. I'm sure all the stock temp gauges read differently. Bottom line: get a real temp gauge.
Old Aug 8, 2006 | 07:16 PM
Drag_N_Fly_One's Avatar
Drag_N_Fly_One
Speed and wind goin into the radiator have nothing to do with when the fan clutch will engage the fan.... The answer is YES it will come on if the engine temp gets to the appropriate temp. Well it's supposed to.
Old Sep 2, 2006 | 02:47 PM
rguidry's Avatar
rguidry
It's been almost a month since my original post. I haven't had an opportunity to tow my trailer until today. I installed an Auto Meter gauge and also replaced the water pump (seal started to leak). Fan clutch is engaging, no doubt about this due to noise produced. Temp gauge reads 200 degrees at highway speed with empty truck. Towing the trailer today at highway speed temp was between 230-240 degrees, quickly drops when speed reduces. Is this too hot? Seems high to me. Is this an indication of blockage in the radiator?
Old Sep 2, 2006 | 03:01 PM
tjbeggs's Avatar
tjbeggs
seems too hot to me. i did some 14k gross towing in back road very hilly terrain with some highway hilly pulls and it ran 200 steady the whole time. i would say the rad is not flowing full out.
Old Sep 2, 2006 | 03:06 PM
Cuda_jim's Avatar
Cuda_jim
Way too hot IMO. You probably need a radiator, but you could remove the radiator hoses and try pushing water through it backwards, bottom to top, just to see if you find a blockage (big chunks) or lots of scale and/or sand.
Old Sep 2, 2006 | 03:18 PM
rguidry's Avatar
rguidry
Thanks for the replies. I was hoping to avoid a radiator replacement, but it has to have some blockage. I'll pull it so I can get a look and make the call to have a shop clean/core it or replace. Thanks again for your input.
Old Sep 2, 2006 | 04:32 PM
cookie88's Avatar
cookie88
FTE Emeritus
One of those cheap Prestone flush kits will allow you to back flush the radiator in your driveway.
Old Sep 4, 2006 | 07:29 PM
DAVID'S97F250HD
To hot yes, before going through the work of pulling your rad, try pulling the grill and look between your A/C condensor and rad and even drop a light between the rad and check your core for blockage.
I just went through this with my friends cummins diesil in his dodge, his rad was plugged solid, went to thye car wash and gave it a squirt, temps dropped after that. Just a suggestion.
Old Sep 4, 2006 | 08:01 PM
ForemanES's Avatar
ForemanES
I had the same thing happen to me a couple years ago. I replaced the factory motorcraft thermostat with a napa one. It would heat up really fast and stay in the middle of the gauge. Pulling a load it would go past the "L" (not good). Had the dealership install a new motorcraft thermostat, they said the napa one didnt open up enough when it needed to. Maybe it could be the same problem you are having. Use a motorcraft part.
Old Sep 5, 2006 | 09:40 AM
FARM69's Avatar
FARM69
One thing I've noticed on my rig is when the fan does kick on my autometer temp gauge does not register any lower? I know when I'm driving a big rig and the fan kicks on the temp goes down 20 or so degrees.
