Clunk from Left Front end
Old Aug 5, 2006 | 10:03 PM
GTABurnout's Avatar
GTABurnout
If I back up then Put it in drive to go forward something in the front end clunks is this a common problem what could it be?
Thanks
Old Aug 5, 2006 | 10:13 PM
kbeefy's Avatar
kbeefy
check shock bushings and sway bar end links.
Old Aug 6, 2006 | 12:25 AM
Badluck's Avatar
Badluck
mine does the same thing but i think its comming from the hub area
Old Aug 6, 2006 | 02:15 AM
kbeefy's Avatar
kbeefy
umm, just to verify, these are 2wd or in 2wd, right? If in 2x, your hub shouldn't be doing anything...
Old Aug 6, 2006 | 03:14 AM
empiretc's Avatar
empiretc
i own 3 fords and they all have that weird sound in the driver side front tire. not really a clunk, but more of a wobble.
Old Aug 6, 2006 | 07:25 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
I have a similar clunk. It's the upper ball joint on mine.
Old Aug 6, 2006 | 10:50 AM
GTABurnout's Avatar
GTABurnout
It is a 4x4
Old Aug 6, 2006 | 10:57 AM
NChornet's Avatar
NChornet
Could be sway bar bushings, end link bushing or hub bearings, also BJ's
Old Aug 6, 2006 | 07:02 PM
Muktown's Avatar
Muktown
it could be your driveshaft splines are dry
Old Aug 6, 2006 | 09:01 PM
cookie88's Avatar
cookie88
FTE Emeritus
Originally Posted by GTABurnout
It is a 4x4
Jack up the left front, see if there's any play in the ball joints. Also check the bushings in the sway bar end links.
Walleye Hunter
Jun 1, 2014 03:41 AM
MDSuperDuty
Dec 5, 2011 07:37 AM
fordex2003
Mar 3, 2010 01:44 PM
TrevorP
Jan 26, 2008 12:23 PM
dempsey64
2004 - 2008 F150
May 4, 2007 06:00 PM
