Some ZF questions
Old Oct 19, 2003 | 01:37 PM
FordPerf300's Avatar
FordPerf300
Some ZF questions
Before I start looking for a ZF to replace my mada m5r2 slush box i have some questions on some differences. First off, do all ZF's have external slaves, if not, which year would i be able to find it on. Also, do any ZF's have a VSS or is this only limited to the 2wd version? I swapped a 9" in my 93 F150 and now i have no where to get my vehicle speed, if the ZF has it, that would be choice. Thanks.
Old Oct 19, 2003 | 03:56 PM
82F100SWB's Avatar
82F100SWB
All of the small block ZF's are concentric slave.
And, for your speedometer reading, on a 4x4, it has to come off of the output shaft of the transfer case, not the transmission.
Old Oct 19, 2003 | 04:19 PM
FordPerf300
Awesome news about the slave. About the speedometer, i have the BW1356 that i'm going to continue using when i put the ZF in. I know that there is no speedsensor on the tcase, so i'm still stuck on what to do with that. I found this slipyoke eliminator that i'm seriously considering on buying and i could use that as part of my VSS. If I were to devide 108 (i'm pretty sure this is the number of teeth on the ring in the 8.8) by 4.56, my gear ratio that would tell me how many of teeth I would need on a ring if I were to run the vss off the driveshaft. I could either get that may teeth cut out of the slipyoke elim. or get a ring with that many teeth cut from it and have it pressed on to the slipyoke elim. Any ideas? Anyone confused?
Old Oct 19, 2003 | 07:55 PM
Toddy's Avatar
Toddy
where did you find?
I was just wondering where you found that slip yoke eliminator from. I am working with my 94 f-250 with a zf and bw1356 as well(I think that is the transfer case I have) any info would be much appreciated. Thanks alot
Old Oct 19, 2003 | 08:02 PM
FordPerf300
I have the link somewhere, i'll look for it tonight.
Old Oct 19, 2003 | 09:19 PM
FordPerf300
http://www.arizonadrivelines.com/sli...liminators.htm
Old Oct 19, 2003 | 10:21 PM
jesse460's Avatar
jesse460
www.chuckstrucks.net they have the vss set up for nine inch fords also 2.5 ton rockwells
Old Oct 20, 2003 | 09:59 AM
FordPerf300
i'll give them a call and see how they set is up for the 9", i'd rather not have it on the axle as it will be closer to the ground and near things that could damage it. I'd kill 2 birds with 1 stone with the slip yoke elim. setup, just have to figure out how to get teeth cut into it or a ring, like the one they have on the 2.5 ton rockwell in the pics and press it onto the slip yoke elim.
Old Oct 23, 2003 | 09:59 PM
jesse460's Avatar
jesse460
a friend of mine had one made for 2.5 ton rockwells but insted of the steel teeth it is made of aluminum and drilled with steel pins inserted into the holes
Old Oct 24, 2003 | 09:47 AM
FordPerf300
i never thought of using aluminum. roughly how much would something like this cost from a machine shop, is it something that I can make drawing it out in cad and carefully use a dremel?
Old Oct 25, 2003 | 10:12 AM
jesse460's Avatar
jesse460
his cost right at about $200 including the aluminum
Old Oct 25, 2003 | 04:32 PM
FordPerf300
bit too much for me to have one made, i'll just draw it out in cad and use a dremel. Hopefully it works.
Old Oct 25, 2003 | 10:48 PM
jesse460's Avatar
jesse460
i dont see why you couldnt make one just be sure to get the steel pins spaced evenly and the right number of them,
montazch
Jan 22, 2017 07:14 PM
'97f350supercab
Dec 4, 2016 08:06 AM
Poorboy1967
Sep 7, 2016 04:53 PM
mountain dewd
Aug 23, 2016 03:50 AM
Morganstrem
18
Dec 17, 2015 08:06 PM
