Sponsored by: Real Truck
Lift Blocks question
Old Aug 4, 2006 | 01:08 PM
junior323's Avatar
junior323
Question Lift Blocks question
Does anybody know where I can buy a set of 2inch lift blocks for an 06 F250 2wd? or if anyone has a set that they want to sell, PM or Email me a price...
I need to lift atleast 2 inches in the back
Thanks In Advance
-Junior
Old Aug 4, 2006 | 02:58 PM
biz4two's Avatar
biz4two
Arrow
Why you need the 2 inch blocks? Just curious...
Also, does your 2wd have blocks now? If yes, what are the measurements?
The reason I ask is that you might be able to find blocks from a 4x4. Just replace your current blocks with the 4x4 blocks. Need to know if you have blocks...because that will determine if you should use the F250 or F350 4x4 blocks. The F250 are just over 2inches...and the F350 just over 3 inches. They list them as 2 inch and 4 inch blocks respectively.
Just some ideas...good luck!
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Aug 4, 2006 | 07:44 PM
junior323's Avatar
junior323
well, i wanted to lift the truck 2-3 inches so i bought a leveling kit (2inches) and now i want to put some 2-3 inch lift blocks
and no it doesnt have any blocks on
thanks
-Junior
Old Aug 5, 2006 | 09:37 PM
biz4two's Avatar
biz4two
Arrow
My original recommendation still stands. Go find yourself a set off an F250 or F350 depending the the amount of lift out back you want. Just take the measurements of the blocks. If you go USED, then you will need to purchase longer U-bolts. Because they are not re-usable according to my FORD service manual.
Also, you should use blocks that are from the same configuration as your SD. IE: CC SB, CC LB, SC SB, SC LB, etc.
Good luck...
biz
Old Aug 5, 2006 | 10:27 PM
kbeefy's Avatar
kbeefy
You'll be fine w/ blocks from a different truck, just find some the height you need. Ford ones would be preferable, but if the height and center pin diameter work then any factory block should work for you. Or a 4x shop should be able to hook you up for around $40, plus probably $25-40 for ubolts. Make sure you get steel blocks, that aluminuim crap is for lowering.
Old Aug 6, 2006 | 01:09 AM
junior323's Avatar
junior323
thanks for the help guys.Does anyone know where or who makes a leveling kit for my truck? i just received my leveling kit from trailmaster and it doesnt fit on my truck. or is there a 2-3 inch lift kit for my truck?
-Junior
Old Aug 6, 2006 | 02:39 AM
junior323's Avatar
junior323
one quick question... would the 4wd front coil springs fit the 2wd?
thanks
-Junior
Old Aug 6, 2006 | 12:04 PM
jlnix's Avatar
jlnix
I to would be very interested in the answer to the coil spring question as I am needing to lower a 2006 F350 FX4 SRW about 2 in.
Old Aug 6, 2006 | 03:57 PM
pamelbert's Avatar
pamelbert
I have 2 inch coil spacers for 2wd F-250/350, I bought them for my dually then took them off before trading, they were on for about 2months, perfect condition.
Old Aug 6, 2006 | 03:59 PM
pamelbert's Avatar
pamelbert
I don't think the 4x4 coils will work on a 2wd, they are probably too big, but I do have a set off of my 2005 f-250.
Old Aug 6, 2006 | 09:10 PM
junior323's Avatar
junior323
how much do you want for them?
Old Aug 6, 2006 | 09:15 PM
junior323's Avatar
junior323
oh and i just compared my friends 06 f350 4x4 with mine and well...the coils on the 4x4 are thicker so they wont fit
-Junior
