Drive shaft
Old Aug 4, 2006 | 10:45 AM
TKKTommyboy's Avatar
TKKTommyboy
Question Drive shaft
I found another 3 speed tranny but it is roughly 5 inches longer in the tail shaft section of it. Would i be better off to have my 2 peice drive shaft cut or to try to locate a one peice? Its a 76 f-150 long bed to have it cut and balanced is roughly 100$ didnt try to find a one peice yet but im sure I could get it at the salvage yard for 100 or less just not sure which way to go.
Any thoughts?
Old Aug 4, 2006 | 11:47 AM
fordraceboy's Avatar
fordraceboy
I'm not sure you would be able to find a one piece that long at a boneyard... if you did, chances are pretty good it'd be bent or unbalanced. i'd just cut and balance the one ya got and go with it... JMO
Old Aug 4, 2006 | 03:28 PM
TKKTommyboy
Good deal Thanks alot
Old Aug 4, 2006 | 08:21 PM
averagef250's Avatar
averagef250
late 80's and early 90's ford E-150 vans have a super long 1 piece driveline that's easy to cut down. Most yards are dirt cheap for stuff like that.
Old Aug 5, 2006 | 08:07 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Yep I agree with raceboy!! Just take the one you have and have it cut to size and balanced.... The problem you'll run into going with a long one piece shaft will be setting up the right pinion angle....and thats critical.....
JMO!!!
Russ
John Ken Howerton
Mar 8, 2016 11:07 AM
79FordBlake
Jun 10, 2010 05:13 PM
fordtrck302
Apr 5, 2008 05:52 PM
nobodyspecial
Appearance & Dress-Up
Nov 25, 2006 09:44 PM
kaised
General Automotive Discussion
Jun 4, 2005 09:59 AM
