Cigar Lighter bulb?
The cigarette lighter has never been used, the power wire was unhooked long ago but looking in the parts manuals and the owners manual, it looks like the socket was illuminated by part # C3TZ-15072-A, "Light for Cigar Lighter"; anybody seen this? Where does it go?
Also, are 1157's the correct bulb for the front turn signals?
Keep 'er between the ditches.
the bulb is a 57 I believe(ck owners manual) the socket is on top of lighter well squeeze bulb retainer and rock to one side tilt up and slide off opposite direction....lots of wire to pull unit down to scope out how it is...socket slides out as i recall....my lighter dont work...what would kill it??? lighter element looks good to me ...suggestions???65CS
)As far as the lighter itself not working, I read somebody on here who had a good answer -- the lighter socket has some wafer fuse at the base inside that deteriorates over time. Makes sense, if the lighter element isn't broken, it *has* to work, pretty much. It's not getting any juice at the socket more than likely.
What's wierd about the turn signal lamps, the owners manual shows 1155 (single element) and 1157 for the front turn signals, but there's only one socket, what's up with that? I'd also like to have the running lights stay on when I turn the headlights on, maybe I'm having a brain cramp, but is that easily done? Seems like that would look better and make it more visible at night, not a bad thing.
