Sponsored by: Auxito
P1406 Code
Old Aug 3, 2006 | 06:01 PM
callman's Avatar
callman
Smile P1406 Code
I have a 98 F150 4x4 5.4L 140,000 miles and just received the P1406 code. I went to a local parts house that checks the error codes. They said I would have to contact the dealer to find out what the code was.
Thanks
Charlie
Old Aug 3, 2006 | 06:55 PM
Kijutsu's Avatar
Kijutsu
<table border="1" bordercolor="#0000ff" width="420"><tbody><tr><td valign="top">P1406 </td> <td valign="top"> DPFE Downstream Hose Off Or Plugged (Ford, Mazda) </td></tr></tbody></table>
Stolen from autorepair.com I think.
P1406 Differential Pressure Feedback Electronic Sensor circuit Downstream Hose
That one is from this site on this page --> https://www.ford-trucks.com/article/idx/7/0/
Hope it helps.
Old Aug 3, 2006 | 07:47 PM
callman's Avatar
callman
Smile
Has anyone encountered this problem? Would it be a hose off or clogged or is the DPFE sensor bad? How would I go about checking this? Where at on the engine would I look to find the sensor? Thanks for your help.
Old Aug 4, 2006 | 12:51 AM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
The DPFE should be under the throttle body cover, on the driver's side of the engine.
There is the EGR tube that runs from the driver's side exhaust manifold up to the EGR valve. Off that are the 2 hoses that go to the DPFE. Check to make sure they are both ok, not plugged, cracked, fallen off etc.
Old Aug 4, 2006 | 01:05 AM
callman's Avatar
callman
Kijutsu and Racerguy,
Thanks for you quick responces on my issue. I will check the hoses out tomorrow. If there is a problem with the hose cracked, clogged, etc. Once I get it repaired I will have to have the code cleared from the OBDC correct? Thanks again for you help and time.
Charlie
Old Aug 4, 2006 | 08:32 AM
Racerguy's Avatar
Racerguy
To clear the code you can just remove a battery terminal for 5 minutes.
Speedjester
Ford Truck Parts for Sale
Dec 12, 2014 11:35 AM
scottgreer
Oct 28, 2014 06:35 AM
sheettvet
Modular V8 (4.6L, 5.4L)
Jun 5, 2014 07:39 AM
Firefighter 1406
Mar 3, 2014 05:40 PM
Firefighter 1406
Feb 12, 2014 05:53 PM
