Sponsored by: Real Truck
2000 V-10 with code P0720
Old Mar 3, 2014 | 01:31 PM
Firefighter 1406's Avatar
Firefighter 1406
Alright. My dad's truck, 2000 F-250 CC 4x4 w/V-10 300,000 miles. He just had the engine light come on. P0720 was the code received. He does plow with the truck and the only other thing I can think of is the muffler fell off the other day. So it stops before the muffler. I had done some research and some say a sensor in the tailshaft of the tranny, some say COPS, some alternator, water in a connector. So I am at a loss? Anybody have any idea as to one of the more common reasons to get a P0720 code and guide me as to where to start?
Thx
Old Mar 3, 2014 | 01:39 PM
DavidB's Avatar
DavidB
Look here:
P0720 Output Speed Sensor Circuit Malfunction OBDII Engine Light Trouble Code | Engine-Codes.com
Old Mar 3, 2014 | 02:58 PM
Wolfboro's Avatar
Wolfboro
As previous post says PO720 vehicle speed sensor located on top of the rear differential . You may have to replace it . Also check the wiring for any damage from broken muffler.
Good luck,
Old Mar 3, 2014 | 03:07 PM
Pitcrw6's Avatar
Pitcrw6
Seth, didnt you buy AE like about a month ago? I know you were talking about it but not sure if you pulled the trigger on it. If you did hook it up and see what it points to.
Old Mar 3, 2014 | 03:10 PM
Firefighter 1406
Thank you guys for the info. I didn't realize that was the sensor it was talking about. I will look into this more.
Old Mar 3, 2014 | 04:07 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Good luck,
No, it isn't the vehicle speed sensor. The problem is the OUTPUT speed sensor on the back, top of the transmission. It is NOT the vehicle speed sensor on the rear diff. He's just leading you down the wrong path.
Old Mar 3, 2014 | 04:11 PM
DavidB's Avatar
DavidB
As I stated:
Look here:
Old Mar 3, 2014 | 05:40 PM
Firefighter 1406
I did. I haven't been able to get it to work yet. I tried on my 7.3 with no success. It's been to freaking cold to try again. I need to though.
Cactus Jack
Modular V10 (6.8l)
26
Jul 20, 2012 08:02 AM
whitefordexplorer
Jan 23, 2011 08:44 PM
dlwilemon
Aug 16, 2007 10:27 AM
