Ford 460 diagnostics problem
Old Aug 18, 2006 | 09:55 PM
tebreuer's Avatar
tebreuer
Some one suggested I change the idle air control, and I did that. It may idle marginally smoother, but it still dies lot. I think the Ford people told me the PCM is obsolete and can only be rebuilt, no replacement is available??? That doesn't make sense to me, but do you know a good place to get one?
Old Aug 19, 2006 | 07:53 AM
subford's Avatar
subford
You might want to try changing the TPS and the ECT (the one with two wires) sensors as they will cause your kind of problem without a trouble code and of course the EGR valve stuck open will cause it also.
I am guessing you have a C6 Transmission with no Computer control of the transmission. As far as the PCM (I think you have the EEC) I have heard this about Ford and Auto Part stores that you have to send it out for repair.
Getting a used one for you RV may be a little hard to find, the only place I can think of is a large RV salvage yard down around Joplin Missouri. They do ship.
If the PCM is bad and has not smoked you may be able to get it fixed at Electronic Repair Shop as when they are repaired them all they do to them is replace the Capacitors and the output switching (grounding) devices or the voltage regulator if they are bad.
If you want replace it you need the program code off the PCM and not the part number. This code is near the plug on the PCM as in the diagrams below. Make sure the one you get has the same program code the ones in the diagrams below is AL9 and HUG2.
http://i54.photobucket.com/albums/g9...ransistors.jpg
http://i54.photobucket.com/albums/g9...rogramCode.gif
Old Aug 20, 2006 | 10:23 AM
EPNCSU2006's Avatar
EPNCSU2006
Do codes 126 334 or 539 make any better sense? My dad's 92 truck has three digit codes, so I would not be surprised if this used the three digit codes too. I would not suggest just throwing parts at it. You'll just spend a lot more money than is necessary and you'll most likely end up replacing a bunch of perfectly functioning parts.
Old Aug 20, 2006 | 11:24 AM
subford's Avatar
subford
126 = MAP/BARO out of range - Maybe unplugged?
334 = EGR Valve not fully closed - Clean or replace.
539 = Maybe the A/C switch was on when you ran the test.
Old Aug 20, 2006 | 10:05 PM
tebreuer's Avatar
tebreuer
I am hopeful this is starting to make sense-I will check the MAP sensor and try cleaning the EGR tomorrow. Any advice on how best to clean it, or is it best just to order a replacemant? The best price I find is about $125, and the MAP sensor is about $100-I hope it is unplugged. It ran worse after I got it back from Ford, so perhaps they unplugged it and didn't hook it back up. I have found several things left loose or unhooked already.
Old Aug 20, 2006 | 10:10 PM
tebreuer's Avatar
tebreuer
By the way, I am certain the A/C switch was on.
Old Aug 21, 2006 | 11:16 PM
tebreuer's Avatar
tebreuer
I want to post a final message of thanks for the help. The MAP, when I found it, was unplugged. The EGR valve was stuck open. I cleaned it, plugged in the MAP, and it idles smooth as silk and runs well too. Thanks very much to all of you for your suggestions and help. The last two posts by EPNCSU2006 and Subford were great!!!
Old Aug 22, 2006 | 12:11 AM
EPNCSU2006's Avatar
EPNCSU2006
Awesome! Glad you got it fixed
jakeupowens
3.8 & 4.2L V6
Apr 16, 2014 08:13 PM
mattmesa
1983 - 2012 Ranger & B-Series
17
Jun 10, 2012 02:19 AM
Ford_Six
General Automotive Discussion
Jan 1, 2012 03:39 PM
tebreuer
Aug 3, 2006 07:18 PM
grove00
1997 - 2003 F150
Sep 26, 2005 06:24 PM
