Dazed & Confused
New to the board but have been reading (lurking) for a while!!
Lots of GOOD info and thanks for it
I try to fix most auto problems myself.... have been reading about
brake light & ABS light and how to solve but I'm some what confused???
Have a 98 f150 standard, 2wheel drive, low miles!!!
Both Brake & ABS light came on at the same time
Had the recall for cruise control done.
Read about replace speed sensor and also about a possible short in the harness...just recently had that recall done.... could that have anything to do with it... brakes are fine, pads, fluid level,pedal , didn't try the ABS
Are the two light the same problem or are they separate???
On my Windstar, when they both light, it is from low fluid. Try unplugging the plug on the master cyl. res. and see if they go out when you restart the truck. If so, it is either too low or you have a bad fluid level switch.
disconnected the plug and the brake light went out....the abs light light stayed on, am I correct that this is normal now that the plug is disconnected?
By they way the fluid level is good.
tested OK,,, the emergency brake switch seem fine also.
I think it all to strange that this happened soon after the cruise control
new harness was installed??? Have to try and reseat that and see what happens!!!
THANKS Again the site is very COOL
I'll keep you posted
Rob
