cab mounted gas tank
Old Aug 29, 2002 | 09:04 PM
cajunbull61's Avatar
cajunbull61
I need a replacement sending unit for my 66 F100. What year trucks would have the cab mounted gas tank? Also where can I get a new voltage regulator for my instrument cluster?
Old Aug 29, 2002 | 09:51 PM
51dueller's Avatar
51dueller
All for trucks had the cab tank until '73. You probally get a sender and voltage regulator in the online store.
Nathan
Old Aug 29, 2002 | 09:59 PM
Tedster9's Avatar
Tedster9
It's called a "constant" voltage regulator and the Ford part number is: B9MZ-10804-C and they are getting kind of pricey. I'm betting that there are way cheaper alternatives from Mouser and any other well stocked electronics outlet.. gotta ask my electronics wizard buddy....
Keep 'er between the ditches.
Old Aug 29, 2002 | 10:56 PM
LxMan1's Avatar
LxMan1
I know that LMC Truck has the sending units and they are only 49.95 and that include the sending unit, new gasket and float. They show 61-72 in the years that are the same.
Old Aug 29, 2002 | 11:09 PM
Tedster9's Avatar
Tedster9
Are you sure you need a new sending unit? The floats go bad on those things typically. They will get a pin hole in them and sort of halfway flop around. New floats are like 6 bucks, genuine Ford replacement. Worth a try - ground out the sending unit and see if the gauge pegs to the high side (only for a second or two to see that it works) If so, the float is likely bad. I used a wine cork when I didn't have anything else on vacation, worked fine for a couple months till it got fuel-logged.
Old Aug 29, 2002 | 11:27 PM
LxMan1's Avatar
LxMan1
The LMC Truck catalog shows a replacement cluster voltage regulator for 61-66 Part#47-0888 for $14.95. They also have just the tank float for $5.95 Part#43-4001
Old Aug 30, 2002 | 10:15 PM
cajunbull61
Thanks for the info. I've requested a catolog from LMC. The sending unit is bad. The coil is kinked up and the contact was hanging up on it. Thanks again!!!!
Cajunbull61
Old Aug 30, 2002 | 10:18 PM
LxMan1's Avatar
LxMan1
Your welcome.
Old Aug 30, 2002 | 10:34 PM
Rosati's Avatar
Rosati
84espy
Oct 5, 2016 03:53 PM
Cobwebman
Aug 28, 2016 12:26 PM
minnesotafisherman
26
Jan 28, 2016 02:21 PM
ThinkItBuildIt
Jul 5, 2015 11:00 AM
1950FordF1
Jun 14, 2015 09:27 PM
